Spring Code?
Old Nov 16, 2013 | 07:34 AM
F2502011's Avatar
F2502011
Spring Code?
I found a chart on here somewhere a while back that broke down the spring codes but I can't find it now. I've got a code VVLL for springs. What does that mean?
Old Nov 17, 2013 | 03:14 PM
marchare011's Avatar
marchare011
Hmmm, no one?
Bueller..... Bueller.....
Did you try GOOGLE?
Old Nov 17, 2013 | 04:43 PM
F2502011's Avatar
F2502011
Originally Posted by marchare011
Hmmm, no one?
Did you try GOOGLE?
I did and have searched this site and many others and no luck.
Old Nov 17, 2013 | 06:40 PM
senix's Avatar
senix
see if this helps:
Ford Door Sticker Decoder .: Articles
Old Nov 17, 2013 | 08:46 PM
F2502011's Avatar
F2502011
Originally Posted by senix
Thanks. It gives an idea, but doesn't cover all models in all categories (seems to be mostly econoline, explorer, f150...) and doesn't give an indication of what year model. I've seen a chart before looking at the differences between front spring ratings specific to Super Duties between snow plow pkg, heavy service, camper pkg, and standard and the codes related to each, but I can't remember where I saw it. Thought it was here but can't find it again here or via Google
Old Nov 18, 2013 | 07:35 AM
720Deere's Avatar
720Deere
VVLL is not a front spring code, at least not a modern one. Try this link Buy 2011 Ford F-350 Super Duty Parts | FordParts.com. If the link works, set the items per page to 75 and less than halfway down you will see all the listings for the front springs and it tells you the weight rating and code for each one.
Old Nov 18, 2013 | 09:11 AM
F2502011's Avatar
F2502011
Great thanks. VVLL is the entire spring code. left front, right front, left rear, right rear. V is the code for the front spring. L is the code for the rear spring.
A=7000 lbs
B=6500 lbs
C=6000 lbs
D=5600 lbs
T=5200 lbs
V=4800 lbs
W=4400 lbs
X=4000 lbs
Old Nov 18, 2013 | 03:34 PM
marchare011
Excellant job guys! Tried to rep ya both but I need to spread more love first.
Hope someone will cover me and rep these fellers.
A=7000 lbs
B=6500 lbs
C=6000 lbs
D=5600 lbs
T=5200 lbs
V=4800 lbs
W=4400 lbs
X=4000 lbs
Nice bit of information to put in my favorites folder thingy, thanks!
Old Nov 18, 2013 | 03:51 PM
720Deere's Avatar
720Deere
A=7000 lbs
B=6500 lbs
C=6000 lbs
D=5600 lbs
T=5200 lbs
V=4800 lbs
W=4400 lbs
X=4000 lbs
I saw in another post where you were looking to get the 6000 lb springs to add height. I don't think you are going to be satisfied with the ride of a 6000 lb spring on a gas truck. My front axle weight as daily driven is around 5200 lbs and the ride is no dream with 5600 lb springs. To offer some ride height perspective, the difference between 5600 lb springs and 6000 lb springs on a diesel is less than 1". I would definitely recommend a 1" bottom spacer over increased spring rate for both ride quality and cost savings. It simply isn't worthwhile to increase spring rate to gain ride height unless you have no preference for a smooth ride.
Old Nov 19, 2013 | 02:37 AM
F2502011's Avatar
F2502011
Right. I went with V code front on the gasser and will add a spring spacer to level the truck out but still have a rake being an F-350. My current diesel has the heavy service front with C code springs. My first 2011 diesel had D codes and rode noticeably smoother than the C code.
johndeerefarmer
2015 - 2020 F150
Jul 18, 2017 01:18 PM
AC-MAN
Aug 25, 2009 05:05 AM
James2
Oct 27, 2007 10:59 PM
aklim
May 27, 2007 06:37 AM
wls
Jun 3, 2006 10:25 PM
