Offroad & 4x4
gear ratios
Old Jun 22, 2003 | 07:56 PM
metallicafan's Avatar
metallicafan
gear ratios
hi everyone, i have a 79 f250 4x4, its got a 351w i havent decided on a transmission yet but ive got it down to the c6 and the 5speed overdrive, i want to run 38in superswampers, but i still want lots of proformance, what gear ratios would i want to run to make this setup go like hell
Old Jun 22, 2003 | 08:03 PM
MustangGT221's Avatar
MustangGT221
gear ratios
Gear ratios are going to depend on the transmission because you have chosen a transmission with and without OD and that's a major factor.
Old Jun 22, 2003 | 11:55 PM
metallicafan
gear ratios
well id kinda like to use the c6 automatic, but if im going to need an overdrive tranny to make this setup powerfull and reletivly highway friendly ill use the 5 speed, what would you do?
Old Jun 23, 2003 | 08:43 AM
MustangGT221
gear ratios
Depends how much you ride on the highway. The 5 speed will be much much better for street friendlyness/highway riding. It'll allow you to use a lower gear (numerically higher) and still not be spinning 3 grand on the highway. With the C6 and no overdrive, you'll have to use a higher gear and you won't have as much of the power. Now, in essence we're really talking about the equivalence of 15-20hp at most.
Old Jun 23, 2003 | 09:00 PM
metallicafan
gear ratios
well ive decided to go with the 5 speed overdrive, what gears would do you sugust with that, also does anyone know of a good place to buy the ring and pinion set?
Old Jun 23, 2003 | 10:05 PM
RRMike's Avatar
RRMike
gear ratios
www.randysringandpinion.com
What 5 speed are you talking about? The zf 5 speed? What are you gonna do with the truck?
Didn't I answer this post in another forum?
Old Jun 25, 2003 | 12:06 AM
MustangGT221
gear ratios
Yes we need to know what transmission you're going to be using because of the OD gear ratio. Also, we need to know what you plan on doing with the truck, lots of highway driving?
wildcard221
Feb 15, 2017 06:23 PM
voadrummer
3.8 & 4.2L V6
May 10, 2015 05:21 PM
dieseldoc
Nov 22, 2006 08:36 AM
dj9124
32
Jul 28, 2006 12:29 AM
gneiss
May 31, 2004 12:32 PM
