Compression Pressure
Old Jun 22, 2003 | 07:42 PM
i_alone's Avatar
i_alone
what is the compression PSI of a Stock 460? looking for both '79 and 88-93, as we have both engines
Thank You
Old Jun 24, 2003 | 01:38 PM
KJKozak2's Avatar
KJKozak2
Man, I wish I could tell you what the specs say it should be at, but I can only tell you what my 71 460 was at.
I had a range from 70psi to 135 psi. The instructions in my tester say you shouldn't have more that 5-10 psi different between the cylinders. I'm re-ringing it tonight as my parts just arrived.
I was once told that 120 psi was good. Did you try a search on this site?
Kevin K.
Old Jun 24, 2003 | 11:08 PM
Superdave's Avatar
Superdave
i_alone
My one year old, rebuilt 79, 460 has 160 lbs. straight across the board.
It has a stock grind replacement cam and has stock 8:1 compression ratio.
Old Jun 24, 2003 | 11:12 PM
i_alone's Avatar
i_alone
cool thanks, becasue the 93 right now only has 125 across the board and it has 8.5:1 comp
Old Jun 25, 2003 | 01:38 AM
ludis's Avatar
ludis
Numbers from an 88 7.5 EFI:
Test 1 (engine hadn't turned over in 6 months): I can't find my numbers, but they were all over the place - like 60 to 145.
Test 2 #1 to #8: 160, 150, 150, 145, 150, 145, 125, 145
Test 3: 165, 145, 50, 125, 165, 165, 160, 145
Test 4 dry: 155, 140, 135, 125, 140, 140, 150, 140
Test 4 wet: 170, 170, 145, 145, 155, 150, 170, 150
In test 3, #3 was really low because the lifter had collapsed due to not enough engine oil.
PS These tests are with a cold engine. I see no way to pull the plugs on a hot engine without burning myself.
PPS I'm having to use a little extention on the tester. The extra volume of the extention must drop the result a few psi.
PPPS This engine has an extreme oil consumption problem that I'm trying to diagnose: Like 3 qts in 100 miles, or 3 qts in 3 minutes of high idle.
Old Jun 25, 2003 | 08:45 PM
i_alone's Avatar
i_alone
still, getting upto 170 for compression, that is I beleive what these engines are suppose to be getting for compression, and the '93 foes through a little bit of oil itself, my Bronc with the 88 460 burns a bit in the morning, especially under full throttle, but I beleive that it is the valve seals leaking, hope to rebuild in the next year, and hoping for at least 400-450 out of the EFI
Old Jul 8, 2003 | 12:21 AM
ludis's Avatar
ludis
An update:
I found and fixed my oil burning problem: The intake manifold gasket was leaking, probably around the #4 port. With a new gasket it no longer smokes! Plus, engine braking has improved remarkably. Going down a steep hill in 3rd without brakes the truck actually slows down.
Old Jul 8, 2003 | 12:44 AM
Mil1ion's Avatar
Mil1ion
Factory pressure on a new 460 is 160-180 Psi
Old Jul 13, 2003 | 02:10 AM
CaseyJones's Avatar
CaseyJones
86 F250 460 200Kmiles (unknown engine milage)
all plugs removed, throttle blocked open, engine almost stone cold.
148-152 in all cylinders. The variance you have listed is way out of spec, I would agree that 10 lbs between highest and lowest is the MOST variance you would want and still consider giving it a clean bill of health.
Tony
Old Jul 13, 2003 | 02:26 AM
ludis's Avatar
ludis
The Ford spec is 25% variance.
Old Jul 13, 2003 | 02:53 AM
CaseyJones's Avatar
CaseyJones
I had no idea Ford allowed so much variance, this is surprising to me but I do not presume to know more than the manufacturer! hehe
My own experience has shown me that such variance might leave an engine with some drivability or performance issues and has without fail indicated a bit of wear, I NEVER buy a vehicle w/o first performing a comp. check, EVER.
I have never personally seen a tight engine exhibit more than about 10% variance, this netted from my experience with various Ford 4cyl, Ford V8 and VW air cooled. This is only from my experience and of course, your milage may vary.
Ford has been very good to me, damn good equipment. I will not question their specs. Enjoy the torque!
Tony
Old Jul 13, 2003 | 03:10 AM
ludis's Avatar
ludis
You might have noticed that my highest and lowest numbers kept moving around. The lowest in test 2 was one of the highest in test 4. I suspect that the leaking intake gasket allowed various amounts of oil to enter the cylinders, causing the readings to vary. I was also doing the tests with a totally cold engine - parked overnight or possible even several days. I'm sure that the lifters which were holding a valve open had plenty of time to leak down.
Old Jul 13, 2003 | 03:13 AM
ludis's Avatar
ludis
I should add that when I got the truck, it had five 24# injectors and three 14# injectors. I'm simply happy that it doesn't have a hole in a piston!
Old Jul 13, 2003 | 11:42 AM
CaseyJones's Avatar
CaseyJones
I hear ya on the lifter bleed down. I let mine run for a while, let it cool for a couple hours, when I did my test it was still a little warm but touchable. I thought I had a burnt valve or something very ugly, a harsh missfire that turned out to be just a couple weak valve springs. I was shocked to see the compression consistant between the cylinders.
I would love to go to fuel injection!!! I might get something a little better than 7-9 mpg!! perhaps one day, a cell phone weilding motorist will smack his/her power stroke into a tele pole, then I can convert do diesel!!
Im glad you didnt find a hole in the piston, replacing pistons is a sucky way to spend an afternoon.
Tony
Old Jul 14, 2003 | 02:35 PM
manstruck's Avatar
manstruck
when checking your PSI - do it with the carb fully open. THis will give you a more accurate #. you dont drive truck with carb closed? Just disconnect the coil and have a friend hold down the pedal.
Ed
