The oldest boy and I are going to work on the stumble by installing new plugs wires and coil as well as draining the trans changing the filter and gasket.
Also the inspection reported the front wheels are not tightened properly.
Since I don't have the Ford Field Service Manuals, I as wondering if there are tables online that give you the proper torque for all or most of the bolts on the 2001 F150?
I know the plugs are 28 ftlbs, hopefully someone else will post the others. Make sure and use Motor craft plugs.
Concur with the Motorcraft plugs. For the 5.4 engine my service manual lists plug torque 84 to 168 in-lbs. My manual also lists all other torque values for the vehicle...to numerous to list. If you need any other torque values just ask. One day I will be able to upload attachments and I upload the whole service manual
