Replacing shocks
Old Nov 14, 2013 | 09:47 PM
FordYoungGun35's Avatar
FordYoungGun35
Replacing shocks
Going to replace the stock shocks.. Figured they've been thru almost 20 years of driving so they need to be replaced.
My bed is off right now so the rears will be easy to get to.. I figured replacing the rear shocks is pretty self explanatory just unbolt the old and install the new..
But the front seems like it would be a little more difficult. Do I have to remove the fenders or anything to change them?
Do all 96' F-150's have dual front and rear shocks? It is a 4x4 short bed single cab XLT.
What can I expect by replacing the shocks? Any noticeable ride improvement? Handling? What shocks should I get?
Are these shocks good? http://www.autozone.com/autozone/par...4_469491_7413_
Old Nov 14, 2013 | 10:18 PM
Evan_P's Avatar
Evan_P
Those Bilstein's seem to be the shock of choice for many. I can tell yo a shock not to buy. ProComp ES3000. They are terribly stiff over sudden bumps and way too soft the rest of the time. I want to replace mine already with less than 10k miles on them. When I do I will be going with the Bilstein 5100's.
As for removing the front shocks, no the fender does not need to come off. Truck doesn't even need to be jacked up. Just grab the top of the shock right above the upper nut with a wrench or vise grips to break the nut free. Once free remove the vise grip, back the nut off, remove the lower bolt and nut and pull the shock out. Installation is reverse of removal. Shouldn't more than 30 minutes to change all of the shocks.
Old Nov 14, 2013 | 11:11 PM
FordYoungGun35
awesome so I picked the right shocks.. I noticed you removed the shocks from your sig, now I know why lol
Do all 96 F-150's have dual front shocks?
Are the rear shocks pretty self explanatory like I said?
Old Nov 15, 2013 | 12:06 AM
Frozen_Joker's Avatar
Frozen_Joker
Yes there are self explanatory Ford. Its even easier since you have the bed off. Lol.
Old Nov 15, 2013 | 09:04 AM
Bob Gervais's Avatar
Bob Gervais
Nope. Dual front shocks, along with front and rear sway bars, was a factory handling option.
Old Nov 15, 2013 | 09:57 AM
FordYoungGun35
sweet so I have good factory handling anyway.. Will I notice any thing different?
Old Nov 15, 2013 | 11:16 AM
Bob Gervais
From 20 year old worn out stock shocks to pretty much any shock, you'll notice a difference, lol. Bilstien are arguably the best though. FYI, I'm pretty sure the 5100 series shocks are only for trucks with a suspension lift. I know yours is lifted, but I forget if it's body or suspension...
Old Nov 15, 2013 | 11:41 AM
FordYoungGun35
Performance Accessories 3" body
Old Nov 15, 2013 | 05:36 PM
Bob Gervais
Looks like the 5100 series is listed for trucks with suspension lifts, probably best to research that before ya buy them...
Old Nov 15, 2013 | 07:53 PM
blkF250HD's Avatar
blkF250HD
If I remember correctly the front shocks have a threaded stud at the top that the bushings, washers and nut go on. In the real world that nut will not come off with any sort of ease. You'll either have to heat it up with a torch and zip it off with an impact, cut it off with said torch or cut off wheel, or use a deep socket and the longest extension you have to snap the stud and nut off altogether. The snap-off technique is nice because then you don't have to extinguish flaming bushings.
Old Nov 16, 2013 | 07:15 PM
warren561's Avatar
warren561
I did a write up on my 4x2 awhile back. Single shock version though, but it should be similar.
https://www.ford-trucks.com/forums/1...ar-shocks.html
Old Nov 16, 2013 | 09:08 PM
FordYoungGun35
Thanks warren! Any ideas on what shocks since 5100 is a nogo
Old Nov 16, 2013 | 10:23 PM
warren561's Avatar
warren561
What's wrong with the 5100? You said you have a 3" body lift, right? I'm not too familiar with lifts, but these indicate they're good for up to a 4" lift:
Rear:
Bilstein, Innovation and High Quality Since 1873
Front:
Front (Auxiliary): No idea what "auxiliary" means
Have you tried calling Bilstein? Their customer service is quite good (from my experience with a warranty replacement for my Volvo).
Old Nov 17, 2013 | 04:06 AM
Bob Gervais
They're talking about a suspension lift, because of the need for a longer shock with a suspension lift.
dixiemudder04
2004 - 2008 F150
18
Mar 9, 2010 11:43 AM
ncheavymetal
Jun 19, 2009 02:43 PM
Shanemh
Nov 8, 2006 09:48 PM
MrDeath8666
Dec 28, 2003 04:06 AM
