electrical problem
Once I got in traffic and was able to slow down to about 75 it went back to 'normal'... Then after my exit had come and gone I was on a back road and climbing a hill. I had to floor it because it was a bad hill, it did the same thing again, and this time the A/C fan sped up real fast... Again when I slowed down it went back to normal.
What is goign on??? I am a little nervous to drive it right now... but if I have to I can as long as I don't have to floor it it is fine...
Any Ideas would be great!!!
Thanks,
-Mike-
I do not know if your van has an external regulator or not....probably not so take the alternator in and get it checked.
But chances are you need a new one...unless you are comfortable getting a rebuild kit and tearing into it. Not really too complicated just follow the instructions included with the kit.
It is running about 15.5 volts at idle, and it is spiking at around 20volts when I floor it, so yeah it definately needs to be replaced...
