6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Bouncing Issue
Old Nov 14, 2013 | 04:08 PM
kurtdnelson's Avatar
kurtdnelson
Bouncing Issue
I've just bought a 2008 6.4L F350 and I've noticed that when I'm at highway speeds and I let off the pedal to slow down for a turn, the truck starts to bounce then stops as the speed lowers. Any ideas what this could be?
Feels kinda like unbalanced tires which I know it is not.
Thanks
Old Nov 15, 2013 | 06:53 AM
Mystic_Cobra's Avatar
Mystic_Cobra
My 09350 SRW bounces a bit over concrete roads when I go over evenly spaces pavement joints. The problem is only there at highway speeds with no load or a light load.
You might be due for a set of shocks...
Is the bounce while braking or coasting or both? Is it only on decel?
Old Nov 15, 2013 | 02:27 PM
kurtdnelson
Bouncing Issue
It seems to happen when decelerating and applying the brakes. I had the brakes checked when I bought the truck. Could it be the tranny downshifting?
Thanks
Old Nov 15, 2013 | 08:20 PM
stevensm's Avatar
stevensm
Have you checked your rear driveshaft u-joints? Not exactly the same but had a good vibration during initial deceleration. At 90,000 mile u-joint at the differential was completely trashed.
bulldogcountry1
Sep 9, 2016 08:50 AM
budtrain
1997 - 2003 F150
Sep 19, 2007 09:02 AM
dlj31
Dec 8, 2005 06:14 PM
Eric Mowrer
Feb 8, 2004 11:56 AM
samaustintx
1997 - 2003 F150
May 17, 2003 12:12 AM
