distributer install
Old Nov 14, 2013 | 02:04 PM
Mike in Ohio's Avatar
Mike in Ohio
distributer install
Putting a new distributer in my 460, the oil pump drive "leans" against the side of the opening below the cam gear. My distributer won't go down over it. The hex looks to lined up fairly well but it won't let the dist shaft slide over it. I tried turning the engine with a ratchet while the dist was sitting as far down as it would go and the cam gear was engaged. Is there a trick to getting the oil pump drive shaft to stay in the center of the opening?
Old Nov 14, 2013 | 05:39 PM
monsterbaby's Avatar
monsterbaby
that's the way I do it is turn the engine slightly with the dist down against the drive shaft. usually it will just slide over as the bottom of the dist shaft is tapered inwards
Old Nov 14, 2013 | 08:38 PM
HAMS64's Avatar
HAMS64
Happen to run into that myself. As i typically drop the oil out when I do work like this, I used a dab of grease on the leaning side to hold it more in the center. Worked!
Hammy
Old Nov 14, 2013 | 10:04 PM
Mike in Ohio
Do you rock it back and forth or turn it one direction?
Hammy
I will give this a try in the morning.
Thanks to both of you, Mike
Old Nov 15, 2013 | 05:03 AM
monsterbaby
I just turn it one direction.
if all else fails use the starter to turn it. once the distributor is into the gear it will turn and not lose timing position. Just remember to not pull it back out without marking exactly where to put it back in or you will need to turn back to tdc and realign.
Old Nov 15, 2013 | 02:28 PM
Mike in Ohio
Thanks again guys the combination of the 2 worked like a charm.
jniolon
Sep 17, 2017 12:10 PM
bearf150
Oct 18, 2006 08:10 PM
biz4two
Oct 3, 2005 12:12 AM
siphor84
Nov 14, 2003 07:28 PM
siphor84
Nov 12, 2003 08:05 PM
