Fuel gauge problems
Old Jun 22, 2003 | 06:17 PM
mlcarey1959's Avatar
mlcarey1959
Fuel gauge problems
I have a 1988 Ford Ranger and the fuel gauge does not register the correct fuel level. When there's about 5 galloons of gas in the tank the fuel gauge registers empty. I have changed the low pressure fuel pump in the gas tank but this did not correct the problem. Does anyone have a solutoin to correct this problem?
Thank You!
Marcus
Old Jun 22, 2003 | 06:52 PM
steve83's Avatar
steve83
Fuel gauge problems
Clean the terminals on the 2 instrument cluster connectors and the tank select switch (if you have 2 tanks). If that doesn't work, you can either live with it or pull the sender and bend the float arm slightly.
