Safe to put very mild programmer without studs being done.
Old Nov 13, 2013 | 11:11 AM
stxbrowneyes's Avatar
stxbrowneyes
I have replaced EVERYTHING ELSE, just haven't done the Head studs yet. Also I want a way to get more throttle response. What is a good exhaust set up?
Old Nov 13, 2013 | 11:27 AM
Mcrafty1's Avatar
Mcrafty1
What year truck do you have? Although I can't attest to the reliability of it I have read on these pages recently that sometime in 06 international realized that the torque robots that were doing the head bolts were out of calibration and therefore not doing an accurate job of tightening down the TTY head bolts. After that the TTY head bolts seem to be standing up somewhat better? but again, I only know what I have read here about that. Maybe some of the Master techs will chime in and tell me how far off base I am.lol!
Old Nov 13, 2013 | 12:31 PM
Misky6.0's Avatar
Misky6.0
The Atlas40 FICM tune from Ed@ficmrepair.com made a HUGE difference in tip-in response which is what is sounds like you are after..
Old Nov 13, 2013 | 12:50 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Agreed....
Old Nov 13, 2013 | 04:32 PM
Ian123's Avatar
Ian123
I also recommend the Atlas 40 FICM tune. Gives just enough power to make the truck much easier to drive
Old Nov 13, 2013 | 11:55 PM
karlsdash's Avatar
karlsdash
mild tune should be alright, but know that anytime you add the extra power you run the chance of losing gaskets. They will let go even on a stock tune, let her heat up on a cold morning, and get some aftermarket gauges if you dont have em. I know of at least 2 trucks that run even the extreme sct tune without studs for a lot of miles (my personal truck is now at 30k on extreme not studded) and a friend is running for longer.
Old Nov 14, 2013 | 05:33 AM
Toreador_Diesel
When I was on the hunt for a 6.0 Excursion, the very same question had crossed my mind. So I thought I'd get the question answered once and for all.
https://www.ford-trucks.com/forums/1...ing-studs.html
Old Nov 14, 2013 | 07:00 AM
stxbrowneyes
Thanks for the info. My truck is an 07 with a build date in 06 . One of the things that I'm after is a faster turbo spool, I have replaced the oil cooler high pressure oil pump brand new turbo new ICP sensor, i PR valve dummy plugs Rails have been replaced. I want a mild sounding exhaust and just a little more power. Whatv is a good tuner to purchase?
Old Nov 14, 2013 | 07:13 AM
Toreador_Diesel
If you want more spool, you want the Atlas 40 FICM tune to start. It greatly helps with turbo spool and helps deliver the fuel economy these trucks delivered new.
If you're still not quite satisfied, I'd get some Gearhead tunes. Matt does a great job turning the 6.0 for power and fuel economy. My truck is studded so I run the SRL+ tune and love the power, shifting, and mileage that come from it. Since your truck is relatively stock, you could run the SRL with a Flo-Pro exhaust and be happy.
Flo-pro makes a great exhaust for the money and it accentuates one of the best things about owning a diesel: Turbo whistle
Old Nov 14, 2013 | 04:49 PM
npccpartsman's Avatar
npccpartsman
Are you running a tuned FICM yet?
Old Nov 14, 2013 | 05:09 PM
beemr's Avatar
beemr
Where can you get the FICM tune, and how much is it? What are the benifits, and does it work well with the SCT tuner?
Old Nov 14, 2013 | 05:20 PM
mustang_309's Avatar
mustang_309
Check out FICM Repair.com - Your Source for FICM Repair there you will find out about all the FICM tunes that can be done as well as making your FICM more reliable.
I run the atlas 40 and the SCT canned 65HP tow tune and have done so for a year now with no problems. One thing i will say is the throttle response is much better with the atlas 40.
The SCT only programs the PCM where as the atlas is a FICM only tune and they can be ran together.
Old Nov 14, 2013 | 05:28 PM
npccpartsman
The FICM tuning is only available from 2 places that I know of. Innovative Diesel or Power Hungry Performance.
PHP is probably the most widely used and is available from FICMrepair.com or directly from PHP for about $150. Benefits include better throttle response, quicker turbo spool, and a little better mileage. There are several levels of FICM tuning, just like PCM tuning. Most people here choose the Atlas 40 but if you're running a big PCM tune you might only want the economy flash. That depends on your tune writer.
Old Nov 14, 2013 | 05:30 PM
Toreador_Diesel
No but I've driven trucks that have one and I know I want one.
It definitely does what they say it'll do.
Old Nov 14, 2013 | 05:36 PM
npccpartsman
Get with Ed and "Git 'er done". You won't regret it one bit....
