6.0 help lost for ideas
Old Nov 12, 2013 | 03:56 PM
Jredd's Avatar
Jredd
I have an 06 excision with no start issues. Scanned it and had a crank sensor fault replaced the sensor and still no start. Scanner reads same icp that the ECM is asking for. Oil level is good and clean. New fuel filters. Ficum module is working bc the injecters buzz with key turning on and it passes the buzz test. And the KOEO TEST it passes also. Fuel pressure is good. It spins over for 30 sec then acts like it try's to start and stumbles then goes back to just cracking. No other codes are present in the ECM. Mods are egr delete, sct programmer. Any help is greatly appreciated.
Old Nov 12, 2013 | 04:10 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Crank Sensor code was from excessive cranking.
What are the FICM volts KOEO, and during crank?
What is the IPR% during crank?
Josh
Old Nov 12, 2013 | 04:12 PM
Jredd's Avatar
Jredd
Volts are good and don't fall off during cranking. Don't know % but will look tonight.
Old Nov 12, 2013 | 04:15 PM
Bullitt390's Avatar
Bullitt390
I want to know what volts you're seeing, not the blanket statement that the volts are "good"
Another trick is to disconnect the ICP and see if it starts.
Josh
Old Nov 12, 2013 | 04:20 PM
69cj's Avatar
69cj
Josh
Easy there Josh!! LOL.
Old Nov 12, 2013 | 04:25 PM
Jredd's Avatar
Jredd
That is my next step is to disconnect the ipr to put it in default. Sorry about being cage with my last post just don't remember exact voltage is all.
Old Nov 12, 2013 | 04:30 PM
BLADE35's Avatar
BLADE35
its only post#2 don't scare him off
Old Nov 12, 2013 | 04:34 PM
Jredd's Avatar
Jredd
It's ok I've looked on here for long time just always kept forgetting to sigh up.
Old Nov 12, 2013 | 04:47 PM
big inch's Avatar
big inch
Disconnect the ICP sensor, not the IPR valve.
Before doing that, check the ICP reading with just the key on and see what the voltage reads. Then crank the engine and see what it reads, along with the IPR.
Also, it is important to know the exact FICM voltage while cranking. A few volts can mean the difference in starting or not.
Old Nov 12, 2013 | 04:50 PM
Jredd's Avatar
Jredd
Ok I'll check that tonight
Old Nov 12, 2013 | 04:52 PM
big inch's Avatar
big inch
Oh yeah, welcome to FTE!
Old Nov 12, 2013 | 05:06 PM
BLADE35's Avatar
BLADE35
OK Good
Then you know when need Exact Numbers for things
Welcome to FTE
Old Nov 12, 2013 | 07:04 PM
04badford's Avatar
04badford
Holy Smokes, like the guys asked you need =
ICPV ( volts)
ICP ( pressure )
IPR ( percent)
FICM MP ( main power )
FICM LP ( logic power )
FICM VP ( vehicle power)
What are you using for a Gauge?
Old Nov 12, 2013 | 07:05 PM
Jredd's Avatar
Jredd
Yes I understand but I was sitting in my tree stand and could not remember them
Old Nov 12, 2013 | 07:07 PM
Jredd's Avatar
Jredd
Snap on solus pro
