Sponsored by: Real Truck
Train horn??
Old Nov 14, 2013 | 08:48 AM
  #31
Slowlearner's Avatar
Slowlearner
Originally Posted by scotttahoe
For the air compressor, I have a cheap piece of crap that I didn't even bother hooking up but plan on buying the ExtremeFlow belt drive from Riffraff. I rather go of the belt for the more volume of air it pushes out. But most people will say that it robs horse power, which it does only when it's on and tell me to go with the electric ones. But I got my mind set.
For the time being I just use the shops air and connect it to the male nipple with the valve to keep the air from coming back out of the tank.
So basically you can blast your horn about 3 times between trips home to fill up your air tank? How long do you plan on running without a compressor?
Old Nov 14, 2013 | 01:01 PM
  #32
scotttahoe's Avatar
scotttahoe
After I had everything in place, I was about to drop some money on an air compressor. I was more or less testing the system for air leaks and trying to figure out what would be the compressor for my setup. So I figured to play with it a little get to work and fill the tank back up, the hard part was done easy part is the compressor for a good one not so easy on the wallet. Unfortunately there were some medical issues that needed to be sorted out and to top it my truck is in desperate need of a turbo and up pipes. Pretty much the E99 conversion kit from Riffraff. So priority over play for the moment. Hoping to have the compressor by next summer, it sucks without one but other priorities for the moment.
Old Nov 14, 2013 | 01:53 PM
  #33
antwan181's Avatar
antwan181
I have a nathan k3la... LOVE IT... a little expensive but ill tell you this... I had the people on a bus pass me and we went through a tunnel and they screamed so hard they had to pull over... its so crazy... just thought id give you some imput
Old Nov 14, 2013 | 06:08 PM
  #34
EXv10's Avatar
EXv10
So you scared those people? That's not what these horns are for.
Old Nov 14, 2013 | 06:19 PM
  #35
antwan181's Avatar
antwan181
Lol yeah I know but sometimes its tempting especially when someone cuts you off... on long island, it happens a lot
Old Nov 15, 2013 | 07:37 AM
  #36
tjc transport's Avatar
tjc transport
i ain't rite
i like to blow my Nathan K5HA's at rail crossings when impatient people cut through the closed gates.
i am sure i have caused a few people to need to go home and change their underwear.
Leatherneck007
Jun 26, 2014 05:43 AM
MoyockPowerstroke
Mar 3, 2009 07:53 AM
JayI10
Aftermarket Products
Apr 29, 2005 03:05 PM
motobub
Electrical Systems/Wiring
Mar 7, 2003 10:12 PM
