I need help with a small engine please?
Old Nov 13, 2013 | 02:46 PM
86ford302help's Avatar
86ford302help
haha, come to think of it I did use the saw right after putting new fuel lines in but then for some reason or another took the carb apart and I bet I put the little diaphragm in backwards.
Old Nov 13, 2013 | 03:05 PM
slimbo13's Avatar
slimbo13
not bettin that ,,,, good luck
Old Nov 13, 2013 | 07:46 PM
86ford302help
I had the fuel lines crossed, now I feel like I should be shot
Old Nov 13, 2013 | 08:00 PM
70-360fe's Avatar
70-360fe
Some good info, I will have to try the stuff from harbor freight. Copper wire does work good when getting into curve passage ways. Get some strained wire and cut off one piece. Welding tip cleaners work good too.
Old Nov 13, 2013 | 08:07 PM
70-360fe's Avatar
70-360fe
Ya but look at all the good info learned. Not hard to miss the easy solution.sometimes. Been there done that, glad you got it fixed!
Old Nov 13, 2013 | 09:40 PM
86ford302help
Thanx for all of the suggestions! You all never seem to fail to have the answers for things.
Old Nov 13, 2013 | 10:09 PM
slimbo13's Avatar
slimbo13
if i remeber right my stihl hedge shears uses 2 different size lines...i was mad... now i understand y
Old Nov 13, 2013 | 10:13 PM
Doug351's Avatar
Doug351
Hey- Glad we could help. I coulda had this solved earlier, but I misread your first posts. I thought you said replaced the fuel lines not re-routed them.
Old Nov 13, 2013 | 10:38 PM
86ford302help
i replaced them, but the old ones were gone completely, it has been sitting in the shed for years. I just misread the diagram I guess
Old Nov 14, 2013 | 11:49 AM
slimbo13's Avatar
slimbo13
hope the firewood piles growin
Old Nov 14, 2013 | 12:06 PM
00BlueOvalRanger's Avatar
00BlueOvalRanger
It happens.
I cleaned out my Dad's old shed, and found a "Homelite" leaf blower that hadn't been started in years.
Replaced the fuel line and fuel 'screen' and it runs like a new one.
Took it over to the farm, where my son and I have permission to hunt/fish/shoot, and did some grass cutting, etc.
Went to start the leaf blower and pulled and yanked and cussed, and pulled some more.
Darned blower would not start, for anything.
I got 'ticked' and tossed it into the back of the truck and swept the driveway and walkway.
Got home and started to throw the leaf blower into the recycle bin, and looked down, and saw that the daggone fuel line was disconnected from the carb!!!!!!!!!
Connected it. Pulled the starter cord twice...... it started right up!!!!!!
I said to myself, "Self. You're an idiot!!!!!!"
(I did not argue!)
Old Nov 14, 2013 | 05:11 PM
86ford302help
Wood pile is growing very rapidly, it's always the small things that make fixing stuff so hard and mind boggling!
Nitramjr
24
Sep 28, 2010 05:54 AM
websthes
19
Jul 7, 2009 12:39 PM
JimmyRC86F150
17
May 5, 2007 06:25 AM
ag-ford-4x4
May 29, 2006 02:19 PM
flathead239
13
May 2, 2006 11:09 PM
