2 cycle engine question
Old Apr 30, 2006 | 04:50 PM
flathead239's Avatar
flathead239
I have a Ryobi 2 cycle weed trimmer about 3 yrs old. It starts & warms fine, but I need to keep it choked to run at all & it doesn't throttle up at all. I can keep it running by pressing the primer, but this is becoming intolerable. I'm thinking it's starving for fuel- what do you folks think? I have fresh fuel, clean plug & have blown gum cutter thru the fuel system- what else should I try?
Thanks,
Jeff
52 F3
02 F250
Old Apr 30, 2006 | 05:11 PM
Traderjoe28's Avatar
Traderjoe28
Sounds to me like the main jet in the carb is restricted. Take the carb off and soak it in a can of "real" carb soak solution (available at any local auto parts store for about $15.00/gallon) for several hours. Follow the instructions on the can, because this stuff is really strong and will strip just about every non-metallic thing known to mankind (including rubber, plastic, paint, and skin). Then blow out all the passages with compressed air after the soaking. The areosol carb cleaners, like Gumout, just don't hack it. The "varnish" and other gunk needs dwell time in the stronger soak solution to soften and dissolve.
Old Apr 30, 2006 | 05:19 PM
53fatfndr's Avatar
53fatfndr
Two things I would check:
1) Clean the screen on the exhaust, if there is one. I had a Shindaiwa that would plug up the screen on the exaust and it would hardly run. After I cleaned it, it ran great.
2) If you don't run it that much, chances are that the carbs are gunked up. It happens on my 2-stroke snowmobiles after a while. Your carb probably needs a good thorough cleaning.
Keep us posted
Old Apr 30, 2006 | 05:41 PM
924x2150's Avatar
924x2150
I just tried seafoaming my stihl weedwacker. It was running a little rough, and probably had some varnish damage. I left the stinking oil/fuel mixture in it all winter. I got it started, let it run for about 5 minutes to warm up the engine, I removed the air filter cover and filter, and sprayed some "deep creep" aerosol-style seafoam into the carb, I cranked the engine a few times with the ignition switch off to get the cleaning fluid into the intake and carb.
I let it sit for about 1/2 hour, and restarted it. It took about 10 pulls, cause I basically soaked the carb, but when it kicked over, I got alot of smoke, and I believe that I may have burned some of the varnish out. The weedwacker ran better after that.
However, I have no clue what the consequences are when using seafoam on an engine like that. I think the seafoam works great on car engines, 4 to 6 HP lawn mower/snowblower engines, etc, and this was the first time I ever used it on a 40 CC or similar size engine. Seafoam seems to bust up carbon/oil deposits pretty good.
Old Apr 30, 2006 | 06:55 PM
53fatfndr's Avatar
53fatfndr
I use seafoam on my 2-stroke snowmobile engines at least once a season. I've never had any problems with it. Just mix it like the directions indicate and you should be fine
Old Apr 30, 2006 | 07:30 PM
ag-ford-4x4's Avatar
ag-ford-4x4
i use seafoam on all engines that run on gas, no problems. Its good stuff. However, it only does so much, so if its still giving problems, i think a carb cleaning is in order. there are some TINY orifices in those carbs, and even a little varnish can plug it up.
Old Apr 30, 2006 | 10:37 PM
flathead239
Thank you, gentlemen. I will keep you posted.
Jeff
52 F3
02 F250
Old May 1, 2006 | 06:58 AM
GlennFordx4's Avatar
GlennFordx4
you could just open the carb adjusting screws a little!
Old May 1, 2006 | 08:06 AM
Fordzlla's Avatar
Fordzlla
Before you tear into the carb, do the following;
1. Fresh tank of premix. Mixing gas with 2 stroke oil shortens its storage life.
2. Clean the air filter and exhaust screen
3. try adjusting the high speed jet. Carefully close it all the way counting the number of turns to an eighth of a turn. Open the jet 1 ¼ turns, start the engine, warm it up.
Hold the throttle open and adjust the jet until you get the best throttle response and highest engine speed.
Old May 1, 2006 | 09:52 AM
hawk's Avatar
hawk
yup main jet is clogged, ya need to take the carb apart and clean out the main jet!!!
Old May 1, 2006 | 10:10 AM
e1p1's Avatar
e1p1
My Deere (rebadged homelite ) trimmer was acting the same way . A local fixit guy told me with a wink that I was "not allowed by emissions laws to remove the plastic anti tamper doohickeys on the carb adjustment screws".
So I went home, did it, turned the screw a 1/4 turn, and my weeds are very unhappy.
Old May 1, 2006 | 11:14 AM
markgilmore1322's Avatar
markgilmore1322
I did the same thing with my Ryobi, and it did the trick
Old May 1, 2006 | 12:31 PM
pchristman's Avatar
pchristman
I always carry those little plastic caps with me when I'm wackin, just in case I see some emission police sneakin up on me. Oh yeah - I also stay up late at night practicing putting them back on in a hurry. Also, this isn't me saying this - I'm just some dude who stole this password.
Old May 2, 2006 | 11:09 PM
e1p1's Avatar
e1p1
My first reaction was ...
then 'cuz that's what we're heading for.
86ford302help
26
Nov 14, 2013 05:11 PM
KevinGnWV
Apr 25, 2011 02:17 PM
Nitramjr
24
Sep 28, 2010 05:54 AM
JimmyRC86F150
17
May 5, 2007 06:25 AM
ag-ford-4x4
May 29, 2006 02:19 PM
