1998 conversion e150- 4.6 engine with c1095 code
Old Nov 11, 2013 | 06:09 PM
rustypierce's Avatar
rustypierce
This is an open circuit code
I have inspected the wiring harness and found nothing peculiar.
What I did find, is the ABS module is a F7UA-2C346-AC and I cannot find this part anywhere on the internet. It does not match what OEM says it should have F8UZ-2C219-AA
It's made by Kelsey Hayes. it has 3 connections on it. It has a 20 pin connector from the wiring harness and another 2 blade connector from a harness. It also has one more 2 blade connection with wire going from ABS module to pump motor.
I have voltage power to the ABS module and also voltage power out of the ABS module to the pump motor.
Any Suggestions for additional testing?
Thanks Rusty
Old Nov 12, 2013 | 05:35 AM
JWA's Avatar
JWA
You might contact user NumberDummy with your part numbers----he has an amazing resource and ability to shed light on superseded Ford part numbers.
This, of course assuming you need a new ABS module. I have no working knowledge of that code or ABS module but have to think it could be an internal issue, one not easily user repairable.
Best of luck in hunting the solution to this!
Old Nov 12, 2013 | 07:52 AM
rustypierce
Thanks JWA, I sent him a PM and will follow up with results!
Rusty
Old Feb 22, 2014 | 06:16 AM
rustypierce
I thought I would follow up on post because many people ask for help, fix the problem and leave the readers wondering about the outcome. My turn to help someone else!
I found one similar on ebay, The numbers did not match exactly however the ebay pictures matched exactly what I have in my van. I purchased it for $35 including shipping. I swapped it out, bled the system and it works perfectly!
No more braking problems with ABS kicking in as you nudge up one car length at a stop light. This was scary and nerve racking because the van would not stop. The only casualty I had was the grocery cart at Sam's Club that I sent flying over 3 rows. I received some weird looks by people in the lot
Old Feb 22, 2014 | 06:18 AM
JWA's Avatar
JWA
Thanks for the follow-up Rusty-----maybe it'll help someone else down the line.
Also glad you've got your brakes back now!
aortizexcursion
Jan 6, 2018 03:24 AM
rockbust
Mar 5, 2017 01:06 PM
fancyketchup
Feb 20, 2015 10:15 AM
