2003 Excursion ignition punched out?
Old Nov 11, 2013 | 10:46 AM
ruffneck30's Avatar
ruffneck30
Had my 2003 Excursion broken into last night [punched out door lock,actually broke bottom half of door handle] Once inside punched out ignition switch[broke black key cover off and then punched out key area and damaged cylinder]
A couple ?'s
-Could they of stole the excursion[is the excursion on the pats II system? chip key?]
-By getting a new ignition cylinder, can the cylinder be rekeyed with my existing key?
or do I have to get a new ignition switch with new keys and new locks[ the door and hatch] and then reprogram the pats II system?
-If needed, can I use Autoenginuity to program the pats II system?
Thanks
Old Nov 11, 2013 | 02:21 PM
Vince79vette's Avatar
Vince79vette
Originally Posted by ruffneck30
Had my 2003 Excursion broken into last night [punched out door lock,actually broke bottom half of door handle] Once inside punched out ignition switch[broke black key cover off and then punched out key area and damaged cylinder] A couple ?'s -Could they of stole the excursion[is the excursion on the pats II system? chip key?] -By getting a new ignition cylinder, can the cylinder be rekeyed with my existing key? or do I have to get a new ignition switch with new keys and new locks[ the door and hatch] and then reprogram the pats II system? -If needed, can I use Autoenginuity to program the pats II system? Thanks
As far as the chip I want to say not as easy but ppl have there ways. And as for rekeying yes they can.
Old Nov 11, 2013 | 07:23 PM
Apocalypse's Avatar
Apocalypse
Yes we have pats, yes it can be re-keyed Yes I would shoot them if I ever caught them lol.
Old Nov 11, 2013 | 07:31 PM
mecdac's Avatar
mecdac
Damn it Jim, they have key.
Old Nov 11, 2013 | 10:55 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
The would be thief thought it was as easy to steal as a Super Duty.
Most thieves know that trying to steal an Excursion is a good waste of time because of the PATS. That's why they just break into an Excursion and go after the 99-07 Super Duties, much easier to steal.
Old Nov 12, 2013 | 06:24 AM
Vince79vette
On another forum I am on (Caco), a guy said his escalade got stoles in less than 3 mins. And after a few ppl chimed in apparently if u know what u are doing u can steal pretty much anything under 3 mins. Our stupid keyless entry makes it easier if u ask me.
Old Nov 12, 2013 | 07:11 AM
Toreador_Diesel
That's because with most Chevy trucks and SUVs it's just a matter of either drilling the tumblers and using a flat blade screw driver or popping the ignition out however they do and starting it from there.
Guy had that happen at the last company I worked for. He came outside at 3:00 to move his 2006 Silverado and everybody thought he left earlier. Well thieves left with his truck. If he didn't have lo-jack, he would've never seen it again.
Old Nov 12, 2013 | 09:16 AM
ruffneck30's Avatar
ruffneck30
Ya just wanted to verify about the excursion with the pats system because it didn't make sense why they tried the ignition with a screw driver, already had my 2000 f250 stolen a couple months ago [found 24hrs later with just ignition damaged and put a new one from a wrecker]
Now what about the key cylinder, can I get a kit off ebay to rekey my own and then put back into the steering column with my original key and will it start?
or do I have to reprogram anyways?
Old Jan 8, 2014 | 08:42 AM
Toreador_Diesel
Hope you got an answer to this....
You can have them rekey a whatever lock cylinder you get to your key. That way you don't have to reprogram a key for the PATS.
Old Jan 8, 2014 | 09:09 AM
ruffneck30's Avatar
ruffneck30
Thanks for checking. I did exactly that, I got the cylinder rekeyed for the original key. [$25.00 at a locksmiths]
Old Jan 8, 2014 | 09:49 AM
Apocalypse's Avatar
Apocalypse
Glad you got it done without having to pay through the nose Now to find those *******s...
FoxFord33
1978 - 1996 Big Bronco
May 8, 2014 05:05 PM
jlgriff76
Oct 20, 2013 09:03 AM
thejim42
Sep 13, 2013 12:56 AM
3spd
Oct 4, 2011 10:28 PM
WARedBear
Aerostar
Jan 27, 2007 12:58 PM
