6.0 question
Old Nov 10, 2013 | 12:33 PM
altonlee's Avatar
altonlee
6.0 question
Does any one know what the injection control reg should read on startup and while running, also what the volts should be.
this is on a 2004 early build 6.0
thanks
Old Nov 10, 2013 | 12:51 PM
BLADE35's Avatar
BLADE35
ICP 580-640
ICPV .18-.24 keoe and .85+ Idle
Old Nov 10, 2013 | 01:04 PM
Rusty Axlerod's Avatar
Rusty Axlerod
ICP- Injection Control Pressure (sensor) psi
Key on engine off 0
Idle 580-625
2,500 rpm 1400-1450
IPR- Injector Pressure Regulator (actuator) %duty cycle
Key on engine off 14.84
Idle 24
2,500rpm 40
fuel pressure regulator
65psi key on and idle
55 or more at wide open throttle
Here's a thread with more spec's and different units of measure:
https://www.ford-trucks.com/forums/1...st-please.html
jaltman1984
Mar 8, 2014 12:17 PM
stokedguy
Jul 12, 2013 09:48 AM
uhoh826
Aug 20, 2009 08:21 PM
wmiller
Feb 23, 2008 10:36 AM
00SvtLightning
Apr 6, 2004 10:29 PM
