emblems
Old Nov 10, 2013 | 12:12 PM
lafermedavid's Avatar
lafermedavid
emblems
I have never bought emblems before,are todays reproduced emblems white alum,or are they plastic,,any suggestions on refurb my originals?thanks in advance
Old Nov 10, 2013 | 02:25 PM
Justin.Hoeben's Avatar
Justin.Hoeben
I have not yet refurbished mine. Still need to get there. But i would say its worth a shot to try and save the original ones. I struggeld to find decent original ones for my truck and they quite expensive to. I was thinking of giving them a quick sand blast. Paint them silver and paint the inside black again. Maybe even try and sand down and polish rather than painting silver. I am sure someone here has done it before. This is what i want to try so can only give you results once done.
Old Nov 10, 2013 | 03:55 PM
co425's Avatar
co425
I'm pretty sure those emblems are pot metal. If so your best bet is to have them replated, or bead blast and paint. Powder coating should be an option as well. They do have some powder coats now that look like polished aluminum.
Old Nov 10, 2013 | 05:09 PM
lafermedavid
emblems
very good so keep the originals,thanks fellas,I asked that ? before but never did get an answer,thats really helpful,Thanks Justin, South Africa that blows my mind
Old Nov 10, 2013 | 06:04 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Plate, name, Ranger 250, Type 7 1977-79
D7TZ-16720-N
Last dealer cost $18.41 list $30.69
White Country Ford Lincoln Mercury, Carmi, IL has 1 (618) 382-4611
B & L Ford, Ashland, PA has 1 (570) 875-4417
Green Sales, Cincinnati, OH has 1 (800) 543-4959
Dennis Carpenter Obsolete, Concord, NC has 1020 (!) (704) 786-8139
Even though these are listed in DC's obsolete inventory if you call, confirm that they are NOS and not reproductions.
Old Nov 10, 2013 | 08:35 PM
VocaTexas's Avatar
VocaTexas
If I get time, I need to finish my Crew Cab's badges. I polished mine with a cloth wheel chucked into an electric drill and used rouge as the polishing abrasive. They shined up pretty nice, except for one small spot where I actually went through the plating. I don't think it will be noticeable when they are on the fender.
Mine are off a '76, so they're a bit different from yours, but I plan on masking the 'highs' where they should be shiny and spraying the rest black. On your style, I read somewhere here in an old thread where the person masked the highs off, then applied the paint with a Q-tip and kind of puddled it, then let it dry.
Old Nov 10, 2013 | 08:45 PM
HIO Silver's Avatar
HIO Silver
Those emblems are toast. They'll be good enough for a driver but not good enough for a near show-worthy rig.
"pot metal" is just that.. it's made from whatever is leftover in manufacturing - aluminum, iron , manganese, zinc, etc. ground up, mixed in a pot, and then compressed at high pressure. The pock marks are indicative of the amalgamation corroding and separating.
Painting... 2x with Voca. "pool" the paint with an applicator like an eyedropper. A better tool would be a flow pen.
Paasche Flow Pen
Old Nov 10, 2013 | 10:39 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Even cheaper pot metal material replacements from LMC are $30 each, DC are $30... so wire wheel yours up, spray them black and then carefully sand the paint off the raised edge and be happy.
Old Nov 11, 2013 | 04:34 AM
montana_highboy's Avatar
montana_highboy
David, didn't you have a post about this earlier?
I have tons of these "emblems" most used,,,,but some NOS
Old Nov 11, 2013 | 07:48 AM
lafermedavid
badges
Thanks fellas,all great info,,,Thanks Montana for your offer,Im leanining towards Rich advice ,wire wheel paint black and sand surface,,,,,I know my badges look rough,but I kinda like the beauty and Beast look,,will see how it goes,at least try: now that you all have given direction
Old Nov 11, 2013 | 08:24 AM
77&79F250's Avatar
77&79F250
Ck this thread out for some DIY badge overhaulin.
https://www.ford-trucks.com/forums/1...ghlight=badges
whitecrystal1
Paint & Bodywork
Oct 23, 2006 03:38 PM
Jmudder79
Paint & Bodywork
Jun 10, 2006 08:01 AM
mzimmers
Garage & Workshop
17
Dec 1, 2005 01:13 AM
66MercMan
Dec 10, 2004 04:08 PM
jwtaylor
Paint & Bodywork
Sep 19, 2003 05:56 PM
