Apologies if this has been covered, but keyword search just isn't working for me to narrow the results to the info I'm trying to find.
The truck has generally been running ok, but since I've installed the Edelbrock I need to adjust it to get it running well. Before doing that I want to make sure the timing is right, but reading through the shop manual it seems it's a lot more complicated than what I'm used to.
Can I really not get it right by connecting a tachometer to the green wire coming from the coil, plug the distributor vacuum tube and set it?
If not, is there a guide somewhere that translates the shop manual? For instance, Step 2 references whether or not the ignition module is PN -12A244- or not, and I have no idea. There are no labels on mine.
I don't have the factory shop manual, I just set it as the emissions label states.
1) Engine at operating temperature.
2) Disconnect and plug vacuum line to advance.
3) Adjust idle speed. (depends on manual or auto)
4) Connect timing light and adjust distributor.
5) Reconnect vacuum and re-set idle speed with throttle stop.
I assume you have the conventional blue grommet DSII module, not the earlier red grommet one that controlled dwell?
That is a basic part number for all ignition modules.
You need to include the year prefix and any engineering revision suffix to identify what they are talking about.
I have used a vacuum guage to set timing and the carburetor ,
I do know "factory" settings are not optimal . while they do work if you don't have tools or a novice though
it is very simple , most manuals (most ,not all ) have a guide to it
or just look it up on the "net" "how to tune with a vacuum guage" they also have it on this forum
I know various ways of setting timing. My real question was that the manual talks about disconnecting things and jumpering stuff, and I was just wondering if you really need to do that (other than the vacuum advance).
It doesn't sound like you do.
I don't know how you time a engine without a timing light. You can use other tools including the seat of the pants method to set the timing,, but you need a timing light before and after to see where you are at before you start, and where you end up when you are done. You can then write down or have in the memory banks the timing number that best suits your setup.
Tom,
If I were you , I would adjust the idle mixture of that new Edelbrock with a vacuum gauge. Then I would adjust the timing.
I have never had to disconnect anything but the vacuum advance.
As I said, the Red grommet modules controlled dwell and there might be some special procedure.
But I have never encountered one, so I have no idea.
Yeah, so far just adjusted the carb. It was too sunny to see the timing marks.
Originally Posted by ctubutis
Yes, 12A244 is the Basic part number for all ignition modules.
Yeah, I sorta figured that out, but what's odd is the manual says if you have basic PN 12A244 module do X, if you don't have 12A244 do Y. But it's in the DII section, so it seems they'd all have that basic PN.
