The exhaust manifold "donuts" have burned out. I do not have access to a lift nor anyway to elevate the truck. Some of the exhaust flange nuts have deteriorated. I plan on cutting my exhaust pipes before the muffler (dual exhausts) and then pull the exhaust manifolds so that I can get to the nuts and get them off somehow.
If I do that, what would be the best way to reconnect the exhaust pipe to the muffler and tailpipe.
I have looked at exhaust connectors and there seems to be lots of them out there.
What do you suggest so that I will not have a leaky exhaust.
I don't know if that would be the best way to approach this. Depending on what truck/engine combo you have, I would to expect to break at least a couple of bolts when trying to remove the manifolds. The FE engine family (360-390) is notorious for breaking the top manifold bolts.
Tell us what truck/engine you've got and we might be able to give you some ideas on how to do this.
To answer your actual question though, I would use this style of clamp to rejoin the pipes.
It is a 74 f100 with a 302. Breaking a bolt into the heads is not something I want to do. I have looked at walker connectors that look good, simiiliar to what you are showing.
I am going to get some blaster penetrant and soak it for a few days and somewhat gently try to loosen the bolts.
You should not have to cut pipes at all. Also I've never seen a ford truck use a gasket on the pipe to manifold joint. Donut gaskets are a chevy thing. I think you need to pinpoint where the leak is first. If it is at the pipe/manifold joint soak the nuts/studs in penetrating oil and try your best. You should be able to let the pipe down out of the way.
Yes, Ford uses both. Usually there is a doughnut gasket on the pipe/manifold joint on the passenger side and on the drivers side there's a doughnut for the heat riser to pipe connection and a gasket for the heat riser to manifold connection.
This is a 390, but you get the idea. In the first picture you can see the manifold is machined for a doughnut.
