white smoke
Old Nov 10, 2013 | 09:03 AM
steelkiwi75's Avatar
steelkiwi75
white smoke
Definitely coolant how can you tell if it is a head gasket or egr ? Or could it be something else?
Old Nov 10, 2013 | 09:24 AM
Fal-308-Win's Avatar
Fal-308-Win
For EGR Cooler, park truck nose down over night and remove EGR valve. Look for moisture in the bottom of the EGR port. For head gasket hook up a pressure gauge to the cooling system and watch for over pressurization. Don't drive the truck!!
Old Nov 10, 2013 | 09:54 AM
RKCORPS25's Avatar
RKCORPS25
X2, don't drive the truck I had this happen and drove it again for about a day and all he'll broke lose. Egr/oil cooler and heads all bad
Old Nov 10, 2013 | 11:32 AM
Fal-308-Win
A ruptured EGR Cooler can turn into a night mare and should be your first concern!! Coolant can seep into a cylinder and cause a hydro lock, bent rods, stretched TTY head bolts and blown head gaskets. After more thought given I wouldn't even start the engin but would jack the rear tires up 10/12 inches and check for moisture in the morning. Remember a ruptured EGR Cooler is most always caused by a plugged Oil Cooler. Here's where a Scangage2 would have alerted you to an arising situation. If the EGR Cooler appears to be O.K. then concentrate on the Head Gaskets. To sum it up : A ruptured EGR Cooler can cause the motor to crawl out of the Engine Bay and Kick THE **** RIGHT OUT OF YOU
catman52987
Sep 16, 2011 05:29 PM
ibrown
Apr 5, 2011 02:03 PM
southbound35west
Oct 27, 2010 08:02 PM
moose122377
Nov 10, 2009 07:11 PM
Reidicus
Aug 12, 2006 09:20 AM
