vacum modulator
Old Nov 10, 2013 | 07:31 AM
rdweathers's Avatar
rdweathers
vacum modulator
I need to replace seal around my modulator, when I pull it out will most the transmission fluid come out also? Thank you. Transmission is C6.
Old Nov 10, 2013 | 07:42 AM
Dave145's Avatar
Dave145
If my memory serves me right, little to no fluid should come out if you remove it.
Old Nov 10, 2013 | 07:50 AM
rdweathers's Avatar
rdweathers
I have tracked down a small leak to this area. I have heard when the modulator has a vacuum leak it pulls the fluid. So I am think some fluid must be in this area and will leak out just not sure how much.
Old Nov 10, 2013 | 08:11 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The seal is a simple o-ring. Very little fluid will come out when you remove it.
When the diaphragm ruptures, the engine vacuum will suck transmission fluid through the cracks and up into the engine. This doesn't mean there's a lot of fluid around the modulator, just that whats there can get sucked up.
Also, there is a pin that goes in the end of the modulator. If it comes out with the modulator, be sure to put it back in.
Old Nov 10, 2013 | 08:56 AM
rdweathers's Avatar
rdweathers
Thank you.
Old Nov 10, 2013 | 09:28 AM
84espy's Avatar
84espy
Where is this located on the tranny?
Old Nov 10, 2013 | 09:34 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Passenger side rear, just above the pan rail.
Old Nov 10, 2013 | 12:00 PM
rdweathers's Avatar
rdweathers
Mike, since you posted that picture. On the same side of transmission up toward the front there is a around cover with four bolts. I may have a small leak around this cover. Do you think you can just get this gasket from somewhere and what is the name of this area that is being covered? Thanks again.
Old Nov 10, 2013 | 01:15 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That's the cover for the intermediate band servo and regardless of the name it's not just the cover, that's actually the servo. It sorta comes out in one piece.
The part number for the gasket is:
D4AZ-7D026-A Gasket, intermediate band servo cover.
There are a few hundred out there, not counting the regular auto parts stores.
Just to pick one, Green Sales, Cincinnati, OH has 77 (800) 543-4959.
Here's the illustration from the Ford parts catalog.
File Type: pdf
Old Nov 10, 2013 | 10:19 PM
84espy's Avatar
84espy
BTW, what symptoms were you having to lead to replacement?
Old Nov 11, 2013 | 04:39 AM
rdweathers's Avatar
rdweathers
No problems other than small leaks.
Old Nov 11, 2013 | 04:45 AM
montana_highboy's Avatar
montana_highboy
Put a stick in it and make it a real truck!
Stop ***** footin around with an automatic.
Old Nov 11, 2013 | 11:46 AM
paredneck33's Avatar
paredneck33
Agreed with Montana sticks are the only way to go in a truck.
Old Nov 11, 2013 | 01:18 PM
84espy's Avatar
84espy
The parts store says that there are 3 different modulators, determined by color band. I checked mine, but it is so old, I cannot get a color off it. I have a 460/C6. Is there anyway to determine the correct color band without having to try them all?
Old Nov 11, 2013 | 01:31 PM
montana_highboy
If you have to engage the tranny via the column shifter....it ain't a truck.....it's a car
Might as well drop it 6" and put magnaflows on it.
