Modular V10 (6.8l)
V10 Excursion starting problem
Old Nov 9, 2013 | 11:56 PM
Doug Manley's Avatar
Doug Manley
<hr style="color:#D1D1E1; background-color:#D1D1E1" size="1"> I've been having a problem with starting the truck for a while but it seems to be getting worse.Some times I can turn the key on to start it and it starts right up. Other times I have to turn the key on and off multiple times to get the fuel pump to come on then it starts.Some times it starts and runs rough and dies,but once it does start it runs fine no problem.It was doing it some last year and I changed the fuel filter but no difference.I don't know if it's the fuel pump,some kind of module or wiring.Any ideas.Parts are so extensive and pulling the tank is a drag so I'd like to figure it out and fix it once.Thanks,Doug
Old Nov 10, 2013 | 02:57 AM
Stewart_H's Avatar
Stewart_H
Moved over to the 6.8L V10 forum so the guys can get you squared away.
Stewart
Old Nov 16, 2013 | 09:40 PM
NovaNewfie's Avatar
NovaNewfie
Check your fuel pressure at the fuel rail. I've been told by other members on this forum that the pressure should not drop more than 10lbs ten minutes after the key is turned off.
Hobie16
May 18, 2017 06:56 AM
Robber80
Modular V10 (6.8l)
Feb 12, 2016 10:29 AM
Doug Manley
Nov 27, 2013 12:25 PM
