Sponsored by: Real Truck
EGR DELETE
Old Nov 9, 2013 | 09:34 PM
bluebird5's Avatar
bluebird5
EGR DELETE
Hello. Lately, I have been getting some high pressurization of the cooling system in my 07 6.0. I'm pretty sure the culprit is the EGR cooler because I have moisture down in the intake. I am aware of the oil cooler issues and will replace when if do the delete.
The delima I have is that if I do the kit with the up pipe, that I loose a point of attachment where the egr cooler once went. With loosing this attachment point, I fear that the bellows will break on the pipe going to the turbo.
How can I attach this straight up pipe where the egr cooler went? Is there any solution on the market. I am sure the bellows will break on the other pipe where it goes into the turbo when I go to the landfill because it is so rough out there.
I am also considering plugging existing egr cooler so that I do not loose that point of attachement. Can I buy one alreadly welded closed by a professional shop?
Old Nov 10, 2013 | 12:43 AM
Pocketlint's Avatar
Pocketlint
You could always try putting in a frost freeze plug, I have heard that works well to plug it off
autonoz
Sep 1, 2011 03:18 PM
s2gots
Jan 5, 2011 05:34 PM
natem8301
Apr 24, 2009 10:49 AM
badbrad60
Feb 25, 2008 11:32 PM
jxdrl
Feb 19, 2008 05:42 PM
