Tool for oil rail oring leak repair thanks to creator.
  #76
Old 11-16-2013, 05:37 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Originally Posted by Yahiko
Thanks Josh.
I tried
You must spread some Reputation around before giving it to Bullitt390 again.
Sean
Thanks. I ordered a set the other day. I have plans to polish the injector spools on the passenger side New Years Day, so figured why not replace the oil rail O-rings too. And the SP/DP as well.
Josh
  #77
Old 11-16-2013, 05:41 PM
Bullitt390's Avatar
Bullitt390
Originally Posted by creator
PM me member price.
Between ebay and Paypal the fees are outrageous.
Dang, just missed out.
Josh
  #78
Old 11-16-2013, 05:43 PM
creator's Avatar
creator
creator is offline
Josh
Sorry should have said something sooner.
  #79
Old 11-16-2013, 07:20 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Creator
Really off topic but.
I would like to get you added to the map.
Sean
  #80
Old 11-16-2013, 07:34 PM
creator's Avatar
creator
creator is offline
Creator
Sean
Currently living in Cottonwood, AZ.
I'm a transporter though so I'm all over the place.
  #81
Old 11-16-2013, 11:10 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
We can always move you pin when needed.
Sean
  #82
Old 11-17-2013, 01:19 AM
creator's Avatar
creator
creator is offline
In my never ending attempt to make things more difficult, I just changed my ebay user ID to cre83r Not to worry the e-oddities* one will work for 30 days also.
  #83
Old 11-17-2013, 11:33 AM
daddykitty's Avatar
daddykitty
daddykitty is offline
I used to work/live in Sedona. I liked cottonwood better. Not as many hippies there that will heal you with crystals and incense.
  #84
Old 11-17-2013, 02:37 PM
creator's Avatar
creator
creator is offline
LOL! Cottonwood is kind of like the armpit of the whole area. Everything kind of flows down here and just settles.
  #85
Old 11-18-2013, 02:47 PM
creator's Avatar
creator
creator is offline
Got the tools today.
The pictures don't so them justice. If you haven't already, PM Mark and get one.
These are way better than the Bostech tool!
  #86
Old 11-18-2013, 04:12 PM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
ROBBINthaHOOD is offline
Thanks for the props. Also fixing to try to come up with an ipr test plug. Got a couple hurdles to cross but hopefully after the first of next month I'll have something rolling.
  #87
Old 11-18-2013, 04:19 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
ROBBINthaHOOD,
On the IPR test tool are you going to put a port in it so
air can be injected from there also? That way if it's not
needed it can just have a plug put into it.
Sean
  #88
Old 11-18-2013, 04:32 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
ROBBINthaHOOD,
Sean
I never really studied it much, but air test goes through the ICP hole not IPR hole, but I guess it could......
  #89
Old 11-18-2013, 04:38 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
If you blocking the vent of the IPR then it should do just that.
I think that is the idea behind this tool. It's a plug.
Sean
  #90
Old 11-18-2013, 04:45 PM
creator's Avatar
creator
creator is offline
ROBBINthaHOOD,
Sean
I think this is a good idea also, especially for a 2003 model with the ICP is such an inconvenient place.
A 1/8" NPT fitting would be perfect and could come plugged by default.
That would take a lot more machining though and add a lot to the cost of the tool. I think most would be willing to pay it though.
You could make 2 versions, a cheap one without and an expensive one with it?
The other idea i had was to make the tip tapered so that it automatically centers itself in the hole. If I'm doing it with the turbo in place reaching way back there it would be nice to know that it centers itself in the hole.
Quick Reply: Tool for oil rail oring leak repair thanks to creator.
