Is This Safe?
Nov 8, 2013 | 07:24 PM
Is This Safe?
6 ton jack stand underneath passenger side axle tube.
I will not be under the truck at all. And yes - I realize I run the risk of someone hitting the truck and knocking it off the jack stand.
I just need to support the truck overnight.
Will the axle tube bend?
Nov 8, 2013 | 07:32 PM
It should be fine . I would like to see it as close to the spring as possible though .
Nov 8, 2013 | 07:34 PM
I normally support it as far to the edge as possible and then once i drop the jack shake the truck a little to check.
Nov 8, 2013 | 07:38 PM
If that's black top get a board under that jack stand. If concrete you're fine.
Quote:
Originally Posted by
2000F250guy
I do too, but due to being in a rush and poor planning, I put the jack there.
Nov 8, 2013 | 07:46 PM
djed
I hear ya!
Nov 8, 2013 | 08:33 PM
i'd rest it on a cinder block
Nov 8, 2013 | 09:32 PM
I'd say chock the front wheels
Nov 9, 2013 | 12:11 AM
Ive had the entire front end up on stands just like that. You'll be fine.
Sent from my Galaxy S4
Nov 9, 2013 | 12:17 AM
A/Ox4
2nd that. your good
Nov 9, 2013 | 12:20 AM
are those the harbor freight ones? if so, i have the same ones.
it's a dually- nice
Nov 9, 2013 | 04:03 PM
73ferdf250highboy
it's a dually- nice
Yes - HF jack stands.
All buttoned up - thanks.
loudoun
Apr 28, 2018 10:13 AM
Rob89
Jul 17, 2017 08:43 PM
speakerfritz
Apr 27, 2015 11:29 PM
locknload223
Nov 26, 2007 06:48 PM
tigerman
Jan 8, 2003 06:21 PM
