Although the operator's manual provides a **** to support their jack, is there anything wrong with jacking the left or right axle beams with a bottle jack placed under the beam at that location?
I like to jack mine as close to the outside as possible. I usually
try to jack just below the spring perches if possible. So to answer your question, the use of a bottle jack is OK.
