backfire and slow throttle response
Old Jun 20, 2002 | 12:32 AM
deadwood's Avatar
deadwood
I have been haveing trouble with backfireing and slow throttle response when I stomp on the gas at low rpms. I pulled all the codes (koeo,koeo) and have no trouble codes. I have the timeing set at 14 btdc (spout out). Recent mods inlclude K&N filtercharger, and MSD6a and blaster coil. I run premium gas. As far as I can tell the TPS, MAP, O2 sensor, EVP, EGR, all test good according to the Haynes manuel. The only other things I can think of to look at would be the Cats to see if they are plugged and the fuel pressure. Oh, it's a 91 f-150 with a 302. If I stay out of the throttle untill the rpms are up around 1900-2000 then floor it I seem to have no problems. For a fuel injected engine I would expect almost instantanious throttle response when the pedal is floored. Any suggestions or advise would be greatly appreciated!! One more thing, I notice that with the timeing light hooked up and the spout in, the timing was retarding to 0 deg. btdc for a second then advancing to 20-25 btdc when I floored the throttle. Does that sound right?
Thanks in advance for any help you guys could provide!
Old Jun 20, 2002 | 02:24 PM
deadwood's Avatar
deadwood
It is a manuel tranny if that makes any difference.
Old Jun 21, 2002 | 09:54 AM
deadwood's Avatar
deadwood
Exhaust shop says cats aren't plugged up. Any ideas guys?
thanks
DW
Old Jun 21, 2002 | 08:52 PM
priley's Avatar
priley
TexasBronco
1978 - 1996 Big Bronco
Dec 19, 2023 08:50 AM
topfile
Aug 12, 2012 10:33 PM
b4hntn
55
Jul 13, 2008 08:53 PM
Four Paws
Oct 20, 2002 10:25 AM
bb79ranch
Nov 30, 2001 09:00 AM
