Lincoln Y block
Old Nov 22, 2013 | 08:01 AM
ZSK's Avatar
ZSK
I think this is a case where pictures can give a better explanation than I can.
Information from: LINCOLN Y
Front sump found in most cars, this is a 368 "Turnpike Cruiser"
Rear sump or "Truck Pan"
Old Nov 28, 2013 | 11:59 AM
C-700's Avatar
C-700
317 heads
Lincoln heads for this series engine are not the same as the truck heads. I am dealing with the same issue. send me an email and I will fill you in.
Old Dec 12, 2013 | 07:26 PM
bigwin56f100's Avatar
bigwin56f100
I have a set of 332 heads from a big job 56 f800
Old Apr 26, 2014 | 07:32 PM
richardge's Avatar
richardge
The rocker arm ratio for trucks were different. Not as much as the Lincoln passenger cars but should interchange since the engines are all about the same. I'd use both rocker assemblies so both banks of your engine match. Should get better performance since the truck engines were de-tuned a lot.
Richard
56bigbackeffie
Projects
Aug 3, 2014 08:02 PM
Old F1
Sep 2, 2010 11:46 PM
arctic y block
Oct 24, 2006 09:45 PM
rtcalabrojr
May 31, 2003 09:03 PM
60f100trk
Mar 16, 2002 12:07 AM
