please help!!!!
Old Nov 6, 2013 | 03:08 AM
nordheimian's Avatar
nordheimian
please help!!!!
I have a 1986 f350 crew cab 4wd 6.9l diesel. I need to find the sending units for both tanks. Part numbers: e5tz9275f and e5tz9275b. Ford no longer makes and I cant find anywhere else. Please help and thanks again!!
Old Nov 6, 2013 | 04:55 AM
Dieselamour's Avatar
Dieselamour
Page 56 and 57 But I do not see the diesel sender for the front tank. Maybe one of the gasser units will work.
Truck Parts and Truck Accessories
Last edited by Dieselamour; Nov 6, 2013 at 05:43 AM. Reason: cleared up information
Old Nov 6, 2013 | 08:17 AM
Chevy_Eater's Avatar
Chevy_Eater
You would have found that info had you looked in the FAQ.
Fuel Tank Sending Units
Old Nov 6, 2013 | 09:45 AM
nordheimian
Wow thanks for that info. Where do I find DAQ?
Old Nov 6, 2013 | 09:46 AM
MPoulson's Avatar
MPoulson
Type this in Google:
"search term" site:ford-trucks.com
Old Nov 6, 2013 | 09:49 AM
nordheimian
Not sure what to type. Im not real good with puters
Old Nov 6, 2013 | 10:11 AM
nordheimian
Ok I looked at this FAQ that was spoke of and still didnt find where I could buy new sending units. Is there antone else rhat can help me?
Old Nov 6, 2013 | 11:39 AM
MPoulson's Avatar
MPoulson
The VB forum search function sucks and always has. Google is better at pulling up relevant threads and even archived threads.
You just type into Google home page
"whatever you're looking for"
and then
or whatever site you want to search.
To answer your question, you can't get them any more.
You either have to find a used one, make one or fix the one you have.
Or, you can try to make something else work. Either way, you'll have to use your prepper/wilderness survival skills. Good practice for when the zombies come.
Use that Google search that I showed you to see how everyone else has solved the same problem.
There are probably a dozen different solutions.
Old Nov 6, 2013 | 02:13 PM
ericconn's Avatar
ericconn
#11 on page 57 of the LMC catalog is the sending unit for diesels. There's no 84 (my model), so if I were to need a rear tank, could I buy this unit, but replace my plug (#13 on LMC) with the 85-86 plug (#14)?
My only suggestion/workaround if the front tank unit is bad and you can't replace it or repair it, you could consider getting the 38 gallon rear tank to make up for the difference.
Old Nov 6, 2013 | 02:37 PM
Dieselamour
Call them and ask that question. I called them when I did my tanks and they were really helpful.
Also, I ended getting my two tanks for about $98 a piece from Advance (online) with a 15% discount, 3 year warranty and free shipping- Made in Canada and rated for biodiesel.
Old Nov 6, 2013 | 04:57 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
they're discontinued brother.you can send them here for reman:
Rebuilt Fuel Sending Unit Specialist
Old Nov 6, 2013 | 06:07 PM
Chevy_Eater
I'd guess that the one for the '85-'86 (rear one only is available) has all the same hookups. The '83-84's didn't have the Cone of Failure on them, so that's probably why they're not listed since technically it's not the same part.
Old Nov 7, 2013 | 05:40 AM
BruteFord's Avatar
BruteFord
Selfish I idea and moderate hijack
How about putting in gasser units? They are available and you get an electric fuel pump. The question is will the gasser electric pump stand up to diesel? I think I've read of others doing this but no reports on reliability. Or if the pump is a worry, use the gasser pickup and sender and put on diesel pump in place of the gasser pump.
Old Nov 7, 2013 | 12:17 PM
ericconn's Avatar
ericconn
LMC has two different electrical sockets, one for for 80-84 and one for 85-86.
Old Nov 7, 2013 | 01:47 PM
Chevy_Eater
Sounds like it was changed then unless that's for gassers, Ford didn't make an IDI diesel pickup in '80-82. I have an 85/86 one in the box at home, I can get pictures for comparison if someone has the 83/84.
Beast 6.9 idi
Dec 26, 2016 12:16 PM
maple sapper
Mar 31, 2012 04:53 PM
Tdiesel
Jun 26, 2010 07:52 PM
bobj49f2
May 19, 2008 04:10 AM
Black88GT
Sep 22, 2005 11:11 AM
