88 2.9 no start right after shutdown
Heres how the start circuit is wired with a manual trans.
From start pin of the ignition switch to the clutch safety switch. This switch is closed when the clutch is depressed.
Next up is the starter relay. This is the slip on/off wire with the rubber boot and red/light blue stripe wire
If you look under the dash near clutch master push rod you'll see the clutch safety switch. These wires are also red/light blue stripe.
It looks like you have a flaky clutch switch that isn't always closing or a flaky ignition switch.
Changing the switch is very simple. Remove the plastic steering column shroud, the electrical connector & the 2 anti-theft screws. I used a pair of vice grips on the screws.
If you have an ohm meter & want to test the switch do this:
Connect your ohm meter to 37 yellow (batt) & 32 red/light blue. Circuit should close only when the key is turned to start. Try it a dozen times.
If you replace the switch, be sure the hole in the switch drops onto the pin in the column.
To remove the steering column shroud remove the 2 recessed screws from the bottom shroud. Squeeze the bottom shroud & remove the upper.
kr98664
23
02-15-2020 10:24 AM
kirbykoon
02-12-2013 08:45 AM
