Major trouble
Old Nov 7, 2013 | 07:31 AM
  #31
pdqford's Avatar
pdqford
Originally Posted by Graham1222
Anywho I took a risk of pulling out the spark plugs without breaking, and got all 4 out. Stuck new ones in with no change.
And did those spark plugs show any sign of running rich?
So much for the "high dollar" scanner.
What did that "high dollar" scanner show for fuel trims?
Old Nov 7, 2013 | 04:16 PM
  #32
largek5's Avatar
largek5
I would put money on clogged cat
Old Nov 7, 2013 | 05:35 PM
  #33
Graham1222's Avatar
Graham1222
Aww damn!!! Um can I run straight pipe without it slaughtering my gas mileage or buy a new one??? What's the cost?
Old Nov 8, 2013 | 08:58 AM
  #34
alloro's Avatar
alloro
If you do your CEL will stay on and you won't pass inspection. That is if your state has them.
Old Nov 8, 2013 | 12:15 PM
  #35
Graham1222's Avatar
Graham1222
Juss heard it's against the law also. I have to pass inspection I live in Texas! Looks like a new one it is. That 500 more dollars......n almost 1000 waisted. Sure hope that's what it is.
Old Nov 8, 2013 | 03:18 PM
  #36
pdqford's Avatar
pdqford
Have you determined which CAT is bad?
I'd suggest you look at the fuel trims to see if that's what took the original CAT out or you might just be setting yourself up for a series of CAT replacements.
Old Nov 8, 2013 | 03:37 PM
  #37
alwaysfords41's Avatar
alwaysfords41
You really need to pay a shop to diagnose this for you. Doing it in the parking lot isn't very effective at this point. $80 an hour is cheap compared to what you have spent and are about to.
Old Nov 8, 2013 | 05:13 PM
  #38
Graham1222's Avatar
Graham1222
Originally Posted by pdqford
Have you determined which CAT is bad? I'd suggest you look at the fuel trims to see if that's what took the original CAT out or you might just be setting yourself up for a series of CAT replacements.
No not yet but I will, thanks for letting me know.
Old Nov 8, 2013 | 05:16 PM
  #39
Graham1222's Avatar
Graham1222
Yeah your right but it's in poplarville,ms a small town where there is barely anything around, surprised they had an autozone!!! That's y I've been doing everything from the parking lot. But you are right I have to find the nearest shop and get it towed there. If they don't tow it on their own first.
Old Nov 8, 2013 | 08:10 PM
  #40
Graham1222's Avatar
Graham1222
And did those spark plugs show any sign of running rich? What did that "high dollar" scanner show for fuel trims?
No, no signs of running rich on the plugs. And I'm not sure if he checked fuel trims. I know when I called to have him come to autozone with the high dollar scanner I described what was going on and he said clogged cat immediately. Then he got there and did his tests and just told me to have a shop change the plugs because I have 122,234 miles and their probably on the original plugs. Not to do it myself, which I did anyway with no problem luckily. But he did get under and was knocking on the cat to see if he heard anything. And advised me that just because he didn't hear anything doesn't mean that's not the problem. He said get it tuned up and go from there. I'd think this 2000 dollar scanner could point to the exact problem but it didn't, he just gave me an option of two things that's spark plugs or the cat.
fosgate3
21
Sep 25, 2020 06:50 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
32
Dec 15, 2019 05:57 AM
CWorthington09
Feb 15, 2018 12:07 PM
Gruffitt
Jul 18, 2010 08:32 AM
XLT2.5L
25
Aug 24, 2009 07:08 AM
