Ok heres another white smoke question. Left for work today noticed a little smoke when giving it power, my trip is mostly highway so I was going between 60-70.On my way home it was blowing alot of smoke when just coasting or on cruise control it was white when I gave it some juice it was black. I got home changed my oil and filter fuel filters are new and I have no codes. After I changed the oil I took it around the block on first start up it was smoking and just continued to get worse and worse as I drove around getting it up to temp. the smoke was bluish white by the time I parked, I pulled the egr it wasn't damp or clogged and I have no codes, My ficm is between 48-49 any one got a clue.
Potentially an injector stuck open! Try not drive it if at all possible
Do bubble test--
The I had is broken so hear is a brief description:
Take off fuel filter cap
remove filter
Turn key to on position to fill fuel bowl
Crank engine w/o starting it
Sorry for not responding the coolant level is normal no loss at all. Im going with a bad injector. I got to clean my garage before I starting pulling things apart, I scheduled a power balance test with ford but I think I will try tearing into it first should I replace the o rings on my injectors while im that deep into it?
If its excess fuel from a stuck injector, you can see fuel where the exhaust manifold meets the block. Just crawl under it and take a look. I just went through this myself. When I saw the smoke and it got worse, as soon as I got home I looked and cyl. 5 had fuel that had seeped out at the manifold.
Worth a look for shure
However the injector would have to be really bad to see fuel running out the manifold
he maynot see fuel running out with say an inject just starting to let go
Severity of Fail may Play into things
If its smoking like he said, its likely hanging open pretty good.
Just key it on while cold, the cyl. will get good and wet, then crank it a few times and crawl under and look.
