1969 shifter/horn ring
Old Nov 4, 2013 | 02:22 PM
saxtonj's Avatar
saxtonj
Hey all....
My '69 F100 Ranger has something broken(I assume) in the steering column. The shifter moves on the upper column but not on the bottom where the linkage goes to transmission. What could have happened to cause that?
I was trying to pull my steering wheel to see if there was something up top that was obvious that I could take care of by can't seem to figure out how the horn ring comes off... what's the trick?
Any help greatly appreciated!
Old Nov 4, 2013 | 03:09 PM
ltharper's Avatar
ltharper
Dont hold me to this but on my '66 you push in on it and turn it counterclockwise.
Old Nov 4, 2013 | 03:38 PM
MIKES 68 F100's Avatar
MIKES 68 F100
push and turn , the clips are pretty much guarnteed to break being 40 years old . they sell replacement clips for cheap .
Old Nov 4, 2013 | 03:48 PM
saxtonj's Avatar
saxtonj
Thanks... I will try that and see if the horn ring comes off.
Anyone have a preliminary idea as to what happened to cause the shifter issue....?
Old Nov 4, 2013 | 04:26 PM
ltharper's Avatar
ltharper
I broke the clips on mine but luckily i had a spare cap that i took the clips off of and put it on my nicer horn ring.
Old Nov 4, 2013 | 09:36 PM
saxtonj's Avatar
saxtonj
Pushed in and turned counterclockwise got it off without breaking clips(whew)
I will see if I can now see what's wrong inside the column.
Old Nov 5, 2013 | 09:13 AM
MIKES 68 F100
this might help you
Old Nov 5, 2013 | 04:20 PM
JEFFFAFA's Avatar
JEFFFAFA
My bet is the 7212 shift tube's tab broke off. Mike's pic doesn't show it much. Ford's fault not Mike's. There is a tab heat staked to the shift tube that over a period of years breaks off. The shift lever moves the shift collar housing. That moves the shift tube I'm refering too. Then the shift tube moves the lever(s) down below. You can either weld it back on or buy a replacement tube. Let me know your vehicle and I'll see about getting you a part number if I'm correct. A/T or M/T? Year of column? P/s or M/s? 4x2 or 4x4?
Old Nov 6, 2013 | 09:26 AM
MIKES 68 F100
you can kind of see it , right side pic #7302 area
Old Nov 6, 2013 | 04:07 PM
JEFFFAFA's Avatar
JEFFFAFA
Yeah but in the pic it doesn't show the top of the tube. Which is where the tab is. It was cool that you found this pic though Mike.
Old Nov 7, 2013 | 09:50 AM
saxtonj's Avatar
saxtonj
For whatever reason I'm not seeing any pic.
To the best of my knowledge the steering column is original to the truck...?
The truck is '69 F100 Ranger, 2WD, 240/Auto, manual steering.
Old Nov 7, 2013 | 11:12 AM
MIKES 68 F100
LINK to original pic
http://www.fordification.com/tech/im...ing-column.jpg
Old Nov 7, 2013 | 03:41 PM
saxtonj's Avatar
saxtonj
Got it! Thanx!!!
I hope to have time to pull the wheel off and have a looksee inside this weekend.
Old Nov 7, 2013 | 04:09 PM
JEFFFAFA's Avatar
JEFFFAFA
Got'cha. Let me know if I was right and you can't weld it back on. If you need to buy one I'll see about the part number.
Old Nov 8, 2013 | 08:21 AM
saxtonj's Avatar
saxtonj
Roger that.... will let you know what I find out if time allows me to check it this weekend.
