Yesterday, I found the assembly line build sheet for my truck tucked into the seat back frame, behind the cardboard cover. It's in great shape and I'm really happy. Actually, there is the build sheet for my truck and the build sheet for a second truck. Must have been the next truck down the line I'd guess.
Anyway, I'd love to be able to decipher this thing, but there are a ton of letters and numbers that don't tell me much. For example, my truck has front bumper "C", engine "F", trans "K", and instrument cluster "E".
Yes, posting a quality picture is the way to go. There are several publications that have information to help decode it, such as the factory shop manuals and the parts catalog. I have an 81 shop manual, which may help but you didn't say what year your truck is. And I have the parts catalog which covers all of these trucks, plus some.
Okay, the truck is an '84 F-150 4x4. Standard cab, 8 ft bed. Midnight blue. Originally a 302 2 barrel and a C6 with a New Process 205 transfer case. Single fuel tank. I believe it has a 3.55 rear with an LSD.
Here are the pics, you may have to zoom in, the print is TINY.
Sorry, I didn't get this done yesterday. However, I did make an attempt and I have to agree with Slash - the pictures are hard to read. I can easily make out what is typed in the box, but in many cases I can't make out what the form itself says.
I will struggle on some today, but if you could take new pics from directly above with better lighting it would help.
I struggled, but cannot do it w/o better pics. Sorry. I don't have a copy of the form to use as a reference, so am dependent upon reading yours from the pic and I can't do it reliably.
And, I want to print yours to work off-line and the only print copy I get from it is tiny. Help!
I recognize some of that stuff from the parts catalog... for example, an air cleaner assembly labelled with "E4TN N".
Most of those other fields, no idea... perhaps from which bin a part is pulled during assembly? This is the sheet that followed the truck down the assembly line and was used by the workers to tell them what to install, I really don't think you're going to find an authoritative, published document telling us what it all means....
I can see it, but I do agree with Angelo - easier to get it off of the Cert Label. I've tried understanding what's in there but it isn't easy. I will try again.
