1978 - 1996 Big Bronco
hubs ID
Old Jun 21, 2003 | 06:23 PM
NJbronco138's Avatar
NJbronco138
hubs ID
I just have a quick question. I read the archive posts and I know if i have 5 screw auto hubs i don't need a conversion kit. I just need the manual hubs. To check to see which hubs i have I just look at the center of the rim right? I went out and looked at what I always thought was just the plastic center cap and it has 5 screws, thats what I'm supposed to look at right? thanks in advance guys I know its kind of a dumb question, but I just want to make sure before i buy stuff and take anything apart.
Old Jun 21, 2003 | 07:13 PM
AlM's Avatar
AlM
hubs ID
yo NJ, Yes; look at this 5 screw hub by Patrick:
http://patricksnorton.com/bronco/hubs.html
vs. a 3 screw auto hub:
http://www.mechanicmatt.com/index.ph...=HubConversion
Old Jun 21, 2003 | 07:17 PM
WhëëlMå1's Avatar
WhëëlMå1
hubs ID
Yes, the five screw hubs are good to go. You need to look at the hub itself. The metal ring that surrounds the 4x4 emblem on the hub has the screws you need to look at. I know I had three. Ive never seen the five variant, but they are out there.
Rich
Old Jun 21, 2003 | 10:19 PM
AbadDriver's Avatar
AbadDriver
hubs ID
well my truck has a small issue. on the right side theres a 6 bolt pattern. on my left is the stock 3 bolt. its kinda wierd but should i go both 3s or 6s?
Thanks
Tim
Old Jun 22, 2003 | 04:05 PM
NJbronco138
hubs ID
thanks guys. I sure its the 5 screw it looks just like that first website one. I linked a picture anyway. So to change them out I won't even have to take off my tire?
http://www.members.aol.com/mrccusm/hub.jpg
Old Jun 22, 2003 | 04:42 PM
WhëëlMå1's Avatar
WhëëlMå1
hubs ID
I would take it off just to give yourself some room to work. You probably dont have to, but I checked all my bearings and brakes when I did mine.
Rich
Old Jun 22, 2003 | 06:10 PM
AlM's Avatar
AlM
hubs ID
NJ,
Yes, you have the 5 screw set-up.
yo AbadDrive, That is a mis-match....go w/the Warn or Milemarker; all same number of screws
Old Jun 22, 2003 | 09:41 PM
AbadDriver's Avatar
AbadDriver
hubs ID
deos it matter what # of screws or either way they bolt right up?
Thanks
Tim
