brass copper mounted in truck with A/C. Makes for easy A/C condenser mounting also.
I keep thinking aluminum. I know they both have their pros and cons. I'm just thinking lighter since I want this truck to have 500hp when I'm done. So I figure just do this right the first time. Just don't know where to get a good quality one preferably made in USA. Thanks boss
If you have a 390 and are planning on 500hp I assume you are doing a 445' engine? It will take some cubes and good cylinder heads to get there.
The Copper~Brass is easy to find and pretty nice quality. The Aluminum-Plastic is ok and of course much lighter.
For my 427 Side Oiler I chose the Copper Brass with fan shroud. Its making a "bit" more than 500hp. LOL
Honestly boss this is all new to me. Sounds like you think the copper brass is much nicer quality. A far as the 445 I haven't a clue hiw to do that lol. But it's ok I have time on my side. Thanks for your input and your 429 looks and sounds badass
Not a big fan of the China junk.. (most aluminum plastic rads)
.030 over on a 390 block (4.080) using a bolt in 4.250 Stroke crank will get you
445 cubes.
You will need the 4.250 stroke crank and a good set of Aluminum heads to get you 500 dependable HP in a 390.
So it really depends on your budget. Expect to spend 5k or more to get you the magic 500hp out of a 390.
445 cubes.
5k or more? Maybe I should get this motor checked out to see if it even worth pouring that kind if money into it or just save up for a crate or something.
