which rear axel?
Old Nov 1, 2013 | 08:16 PM
Madrid1214's Avatar
Madrid1214
which rear axel?
Okay I'm here to bugs you guys again. Of course you guys know I have a 1964 f100. My rear differential is a heavy duty one, 8 lugs. I found a 5 lug that came off a 66. All complete for 250. But I want to put power brakes on. Should I get the 66 with a 5 lug and add an after marketconversion kit? Or just get a newer rear differential that has disc brakes and use the power brakes from that truck? What do you guys recommend? Thanks!!
Old Nov 2, 2013 | 04:43 AM
jowilker's Avatar
jowilker
1964 Ford F100s don't have 8lug Danas on the back. Do you have 5 or 8 lugs on the front?
John
Old Nov 2, 2013 | 07:54 AM
Madrid1214's Avatar
Madrid1214
5 up front. Original owner took the bed off and put a platform on it as well switched the rear to a 8 lug.
Old Nov 2, 2013 | 08:34 AM
Shadowrider123's Avatar
Shadowrider123
$250 for a complete 5 lug rear end is to much money IMO. I see them all over the place for $75-100.
I bought a complete one for $75.
You need to consider what engine and tranny you have an the use of your truck so you get a rear end with the proper gearing.
Old Nov 4, 2013 | 04:13 PM
Madrid1214's Avatar
Madrid1214
I thought about it but since you mention it, I'll check out the junk yards. I just happened to stumble upon this when looking for a short bed. It's been tough. I find them all over except AZ.
Back to the rear differential.
What about be the best set up? Find a donor that has power and use the power brakes from the same donor or purchase an older vehicle and just upgrade them?
Old Nov 5, 2013 | 03:41 PM
charliemccraney's Avatar
charliemccraney
Be aware that any newer axle will not simply bolt up. At least minor modifications will be required to the truck and/or axle.
Old Nov 5, 2013 | 09:08 PM
CropDusterMan's Avatar
CropDusterMan
Hi there Madrid,
Well, a couple of ideas for thought...having 5 lug up front and 8 lug in the rear will make things interesting if you
have a flat one day...I doubt you want to carry two different spares! I think you said your old truck is an
F100 which was originally the Ford 9 inch. I think you need to find one of them, or else you have a
lot of work trying to redo the front to match the rear-and the F250's are more limited in rim/wheel choices than
the 5 lugs are. (IMHO)
The old F250's use an 8 lug Dana 60 rear end-there were several different versions-with minor differences, but all
were drum-style brakes. The 65's and 66's are a little different from lets say a 1972, with the later ones having
slightly wider drums for improved braking, and different differential yokes-the 1966 was a ten spline for instance,
yet the '72 was a 29 spline-simply involves the use of a conversion u-joint. If I'm not mistaken (with DANA 60's),
anything up to a '72 will bolt in, but I heard that the '72's and up were a little wider (I may be wrong on that though).
Tex51
25
Jul 6, 2018 08:00 PM
Kmw3ut
Jun 24, 2016 02:42 AM
hotroddoc
Jan 29, 2005 09:37 AM
NissterlingFFbuggy
Offroad & 4x4
Feb 1, 2004 03:04 PM
Wayne
Jan 3, 2000 11:44 AM
