Lost Compression in a cylinder.
Hey guys, I got a question for you. One of my friends has bought a 68 F100 with a 351W (I think). Well unfortunately for him, after he bought it, the guy that he bought it from said that one of the cylinders doesn't have as much compression as it should have.
So, my question for you, cuz I'm not as much of a truck guy as I wish I was, and my friend knows nothing about cars.
How does a cylinder lose compression, and what can you do to solve the problem?
Any help would be wonderful.
Thanks, Frankie.
Thanks, Frankie.
Flyboy is right....What about burned valves?? that could cause it. turn it over to TDC on the leaking cylender, and listen through a hose. If you hear a hiss from the carb, it is getting by the intake valve, if through the tailpipe, its going through the exhaust valve. If you pull the PCV valve and hear it, its the rings. You *might* see bubbles in the antifreeze if its leaking through the head gasket into the cooling system, not sure...
52runner
23
02-13-2015 12:20 PM
scottandrews74
11-14-2013 12:42 PM
TexasMarkIII
07-30-2013 12:28 PM
FordFETruck
03-12-2012 02:37 PM
