Seat Conversion?
Old Oct 31, 2013 | 04:19 AM
Hutch_Slapper's Avatar
Hutch_Slapper
Seat Conversion?
I have a 96 single cab f-350 with the single 4 bolt bench seat, I recently went to pick and pull and found some 40/20/40 seats out of a 1999 for f250 super duty... how do I get these in my truck with out custom fabing spacers?
Old Oct 31, 2013 | 04:47 AM
Diesel_Brad's Avatar
Diesel_Brad
Its, simple..... You DON'T
Old Oct 31, 2013 | 04:49 AM
Hutch_Slapper
They don't make any seat pans?
Old Oct 31, 2013 | 06:13 AM
Jarryd's Avatar
Jarryd
You'd have to do something custom, not sure how much. They'll sit high too.
Old Nov 1, 2013 | 04:20 AM
Diesel_Brad
No Ford discontinued them a couple of years ago. I have been hoarding them since
Old Nov 21, 2013 | 02:01 PM
smares's Avatar
smares
OK
"No Ford discontinued them a couple of years ago. I have been hoarding them since __________________
96 F350 CCLB 460 5pd 4x4 /97 F250 CCSB Dually 7.3 5 spd 4x4
94F150 RCSB Lightning/86 F250 RCLB 6.9 4spd 4x4
80 F350 RCLB 429 C6 4x4/
04 Ranger SCSB
96 Bronco 347 5speed"
Then you wouldn't mind giving up a couple of them for my passenger seat, right? I only need two of them.
Old Nov 21, 2013 | 04:51 PM
BiGGreen350's Avatar
BiGGreen350
04 Ranger SCSB
not sure you understand how the pan looks
bottom side with seats bolted to it
top view with seats bolted
top view no seats
bottom view no seats
another top view no seats
Old Nov 21, 2013 | 05:10 PM
smares's Avatar
smares
Wait, is that front seats or rear??? I need front. That looks like they sit way too low to be front seats. Besides, if it is front, then that won't work for me with that pan setup. I need the center area clear for the console.
Old Nov 21, 2013 | 06:10 PM
BiGGreen350
fronts,
and get ready for some fabrication then, because the only ones that had seperate brackets for each seat and center were in extended cabs and broncos, which have an entirely differnt floor contour than the reg cabs and crew cabs, and since you have a regcab, your a few fries short of a happy meal, good luck, and note that if and when you drill hole in floor and mount the seats, reinforce the floor, and not just some big washers, like weld or bolt in a support like the factory mounts, or else you can count on the seats ripping through the floor if ya ever wreck, which doesnt sound enticing to me
Old Nov 21, 2013 | 08:58 PM
eakermeld's Avatar
eakermeld
Originally Posted by BiGGreen350
fronts,
Ejection seats?
Old Nov 22, 2013 | 01:55 PM
smares's Avatar
smares
fronts,
No, I do have the extended cab, but not superduty. Do you think the Bronco seats would fit without modifications into the F250 I have (IE they have the same floorpan or bolt layouts)? I have a feeling I'm still going to be hungry for fries after all the work I think I'm going to have to do to get this seat to go in properly. I have a pair of risers that came with the seat I bought from a junk yard. I think I'm going to just cut off the bottoms of them and recreate new 'feet' that line up with the holes I already have in the floor.
Old Nov 22, 2013 | 02:59 PM
BiGGreen350
my bad, didnt realize you werent the original poster, i figured it was the op that i was responding to and he said he has a single cab.
if you find bronco or extended cab seat brackets, you can mount the superduty seats to those(if they line up,,, not too sure if they will) and then mount the obs seat brackets to the factory mounts in the floor
Old Nov 22, 2013 | 06:46 PM
Diesel_Brad
I would get the 3 pice seat pans from a 94-97 super cab and mount the SD seats to them. That way they will bolt in and not be an abortion. Just a FYI, SD seats do NOT side forward to access the rear like OBS seats do
ND_Stroker_6.0
Jun 15, 2016 09:48 AM
adam22827
Apr 16, 2014 02:45 PM
traildogg
Dec 10, 2011 12:44 PM
jc8825
Aug 28, 2011 05:20 PM
blb58
Jul 17, 2003 11:14 PM
