300 stroker engine
Old Jun 21, 2003 | 09:51 AM
Mechanix185E's Avatar
Mechanix185E
Unhappy 300 stroker engine
I can't seem to find anything on this, and everything I find in a forum is always just forgotten about, does anyone know a way to stroke a 300, because I'm trying to decide on what to use. I'll use the 300 if I can stroke it and get some more power, if not I'll probaly use a stroked 460.
Old Jun 21, 2003 | 10:31 AM
F150daniel's Avatar
F150daniel
300 stroker engine
I asked the same thing, they said that the six has a bad enuff rod ratio already and some othter stuff about heads.
I would like to see it done with 4.500" (340ci)stroke, Crower makes custom cranks have the heads ported get some custom pistons, maybe rods. lots of tq and good MPG
Old Jun 21, 2003 | 02:02 PM
StrangeRanger's Avatar
StrangeRanger
300 stroker engine
Clifford used to make a 4.38" stroker kit for the 300, perhaps they still do. The problem is that the head would need a LOT of rework to breathe well enough to accomodate that much more displacement. You'd also need a pretty trick cam because you need a lot more lift but you wouldn't want to increase duration any more than absolutely necessary since the resulting engine is not going to pull any revs. Why bother?
Old Jun 21, 2003 | 07:45 PM
Mechanix185E
300 stroker engine
Yeah, I'm starting to think its not worth it, I'll probaly go with the stroked 460.
Stephen67
Mar 15, 2016 07:21 PM
OKC_65_F100
Aug 14, 2010 10:15 AM
Ruckus
Garage & Workshop
22
Oct 2, 2006 07:40 PM
Madmike33
Mar 18, 2005 07:45 PM
breakemlose
Sep 25, 2001 11:06 PM
