Sponsored by: Real Truck
Fitted winter fronts
Old Oct 30, 2013 | 09:10 AM
Mcrafty1's Avatar
Mcrafty1
Hey all, I have an 07 350SD and am considering a winter front for obvious reasons ( I live in north central Maine and the temps get very cold here in winter (19* the past two mornings and 40's during the day) I would like to have a fitted front that didn't require drilling the chrome grill and would like to know if anyone has a link to some that don't require that? or a link to a thread here would get me pointed in the right direction would be good too. I have read about the fronts with the stick-on type grommets but all say the don't stay. So what if any options do I have? Thanks for any input, it will be much appreciated P.S. and yes I have done the cardboard behind the grill before, LOL It's just not that pretty.
Old Oct 30, 2013 | 09:29 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
2005-2007 Ford F250 Fia Custom Fit Grille Cover - Fia WF922-13
Yes it uses stick on snaps, but mine has been in place since 2007 and haven't ever come off. Just clean under the stickies before you put them on.
You can see the little black nubbin deals in this pic:
Maybe buy a cheap second grille if you're worried about appearances when the cover isn't installed:
http://www.partsgeek.com/gbproducts/...FQif4AodwDkAEw
I'd rather have the positive and easy attachment snaps than dealing with straps like the OEM ones that came with the 6.4Ls.
Old Oct 30, 2013 | 11:17 AM
Chalkie's Avatar
Chalkie
I have the Fia cover on mine as well. Have not used the winter cover yet, but the bug screen is great. It kept tons of bugs out when traveling thru bugland (NE, KS OK, TX ) in the summer.
It has been thru multiple car washes, even the one that have the big spinning brushes and the snaps have not come off. As Texastech said, clean the area where you are installing the snaps really well.
Old Oct 30, 2013 | 11:36 AM
madsonp's Avatar
madsonp
You shouldn't need one until you get well below zero like in the -30 deg range. An old trick we do here in Montana is just put a piece of cardboard in from of the radiator, it's a lot cheaper, then when it warms up you just pull it out.
Old Oct 30, 2013 | 11:37 AM
Misky6.0's Avatar
Misky6.0
ditto, I have the FIA fitted cold weather and bug screen combo also.
I did order the drill on tabs (haven't used them yet).
I find the bug screen ends up leaving a stain where it contacts the white painted grille (vs. your chrome). My grille is cracked, so I wasn't too worried and I do plan to use the drill on tabs once i get all of them positioned perfectly (one or two need tweaking to get them just right).
The cold weather cover REALLY helps when it gets into the 60s here in FL, 'cause my BPD oil cooler works way too good to keep the oil hot when I am cruising around
Old Oct 30, 2013 | 02:57 PM
Mcrafty1's Avatar
Mcrafty1
Ok, so it would appear the stick-on retainers will work with a little extra care putting them on. That being said if they DO come unglued will the screw on type retainers work with what ever is on the front itself? or are they unique to the ones that come with the front that are glued on?
................. and I know I don't NEED the front until it gets a lot colder than the 20*above I'm seeing now BUT diesels are like women they like to be warm and will give you better service if you make them happy. Just an observation that I have found to be true in most cases.
Old Oct 30, 2013 | 03:08 PM
texastech_diesel
Token Redneck
A few of my plastic snaps took rock hits over the years, I got a little baggy of plastic snaps off eBay and they worked. It had a weird sizing thing on it, like #20 or something. I'd assume (yeah, I know) that metal ones in the correct size would work just fine.
I'm all for running the cover. It warms up faster, stays warmer while driving, doesn't seem to screw with my IAT2 reading, and doesn't make the fan run weird, so it doesn't seem to be hurting anything at least.
Old Oct 30, 2013 | 04:21 PM
Mcrafty1's Avatar
Mcrafty1
I'm with you on running the front simply because of the things you mention plus when you stop for a bit, or in my case I'll be plowing driveways which will do little to work the engine I believe it will be better for the engine if I can maintain a more constant temp. on the warmer side of the scale. It being my first winter with this engine i will have a learning curve, hopefully I will be able to use this truck similar to the way I used my gassers in the past and still keep it together and running well......time will tell.
Old Oct 30, 2013 | 09:23 PM
texastech_diesel
Token Redneck
Be careful behind a plow with a cover though, running with it raised up can cause issues; that's why the plow package trucks came with a different fan clutch that helps move air when direct flow is blocked by the plow. If you have an ECT gauge you'll be fine because you can see the actual reading and won't overheat anything.
Old Oct 31, 2013 | 04:15 AM
Mcrafty1's Avatar
Mcrafty1
You may be onto something, when I brought the truck home after the plow installation (that was in July soon after I bought the truck) the fan run a few times just traveling along the highway. It is the only time I have heard the fan run, so just maybe I should wait until I run the truck with the plow before I spend the money for a front that I will not be able to use much. the cardboard behind the grill will work for the times I'm not hooked into my plow. Thanks for the input.
I do have a SGII and monitor my ECT, EOT, battery volts and FICM volts all the time but if I can't use a front without a hassle I may just do without for now.
Old Oct 31, 2013 | 09:41 AM
PSDlongbox's Avatar
PSDlongbox
I'm sorry, did you say 60...as in 60 degrees above zero.....
Old Oct 31, 2013 | 10:49 AM
texastech_diesel
Token Redneck
With a BPD oil cooler and no cold-weather kit, yeah it could be a problem. If it's running way to cold because of the massive oil-to-air heat exchanger he added up front, he has to do something. Personally I'd just add the kit to keep the oil at least at 180*, but cheap fixes are cheap.
Old Oct 31, 2013 | 03:52 PM
PSDlongbox's Avatar
PSDlongbox
Why can't you just use a thermostat in the oil line to control temp?
Old Oct 31, 2013 | 05:32 PM
Mcrafty1's Avatar
Mcrafty1
While I don't have a BPD oil cooler I don't believe you could put a thermostat in an oil line. Oil is not meant to be held up along the loop from the pump into the engine and back to the pan it isn't like the cooling system where the thermostat holds the water in the engine until it reaches temp and then lets it flow again. Oil lubes the friction points by way of pressure without the full flow you don't have full pressure. Are you confused yet? I know I am.LOL!
Old Oct 31, 2013 | 05:34 PM
PSDlongbox's Avatar
PSDlongbox
You don't block the entire flow of oil. Its like a trans cooler thermostatically controlled.
