What else to do when installing EGR delete?
Old Oct 29, 2013 | 06:37 PM
Pridnjoy's Avatar
Pridnjoy
Looks like I may have a bad EGR cooler on my 2005 Excursion with 94k miles.
Looking at the IPR Gen2 delete kit (unless any better suggestions). I am thinking that I should also replace the oil cooler (Ford # 3c3z6a642ca ?). Anything else that needs to be done since I will have the engine tore down?
What about?
Stand pipes/dummy plugs
Turbo oil line
Turbo clamps
New belt
Boots
Any insight would be great. Don't want to do unnecessary stuff, but also want to do what improves longevity and reliability.
Old Oct 29, 2013 | 06:45 PM
Misky6.0's Avatar
Misky6.0
Do you have a sg2? You need to monitor your oil vs coolant temp delta, once fully warmed up..
What makes you think the egr cooler is bad?
Flush the coolant before you replace the cooler(s) and consider a Coolant filter.
Most '05 excursions have '04 engines, ford had left over. Built dates around june '05 is when they got '05 engines.
Sent from my Sprint PC36100 using IB AutoGroup
Old Oct 29, 2013 | 06:50 PM
Pridnjoy's Avatar
Pridnjoy
I have an Edge Insight. My delta runs about 6-7 degrees. I had the coolant flushed about 600 miles ago and installed a coolant filter.
This weekend I had significant amount of white smoke on start up and the first 10 mins of driving. Then no more. Slightly less coolant in degas bottle with no evidence of overflow. No codes at all on Insight...
Old Oct 29, 2013 | 06:55 PM
Misky6.0's Avatar
Misky6.0
Park nose down overnight, check under the egr valve for wetness, if its the egr cooler. Monitor ficm voltages too.
greentree ford
Jul 16, 2013 07:10 AM
mkoser
Feb 15, 2012 08:59 PM
Teds
Jan 18, 2012 06:22 AM
Raven855
Jan 21, 2011 08:04 AM
mnky30
May 31, 2010 06:16 PM
