Sponsored by: Real Truck
99 man lockouts....HELP!
Old Oct 28, 2013 | 08:08 PM
evanshea's Avatar
evanshea
Replacing lockouts due to pas side being stuck. Diver side came right out but the pas side is completly stuck. I have tried all the tricks I could find on here for getting it free.....I have sprayed it with lube a bunch and let it sit for hours, have hit it back and for for about 2-3 hours. The big question I have is can I use a torch and heat it up and see if that will work. Thanks in advance for any help.
Old Oct 29, 2013 | 05:36 AM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE, evanshea.
It can be stubborn, but it will come out. Use penetrating oil like PB Blaster (not lube like WD-40) ans soak it a few hours. Whack the sides a few times with a mallet, then wiggle and pull.
Also, it's already broken, so use of force isn't going to break it more.
Old Oct 29, 2013 | 09:40 AM
krewat's Avatar
krewat
Using a torch is iffy in a tight place like that - too much grease, rubber seals, and other stuff in there - who knows what's going to happen.
Soak it soak it soak it. Put a big monkey wrench on it
Old Oct 29, 2013 | 10:13 AM
wbrook_ford's Avatar
wbrook_ford
I had the same problem on my 03 driver's side hub.
What I did after a week of hammering was get 4 hose clamps, 1" or 1.5" diameter, and hook them all together to get a single hose clamp with 4 screwheads.
Tighten the hoseclamp assembly to the hub, making sure all 4 screws were roughly 1/4 of the way apart around it.
Take 2 prybars and pry against the hoseclamps directly outward. I used 4 so I could go up down and side to side.
Breaking that corrosion this way made it pop right off.
Platinum08
Jul 13, 2014 10:10 PM
Bluethunder3320
Aug 25, 2012 09:18 AM
st-15
Oct 29, 2011 03:05 PM
ghig1967
Jul 18, 2010 12:40 PM
ghig1967
Jul 17, 2010 03:36 PM
