2000 V10 Excursion Not Starting
Old Oct 28, 2013 | 06:38 PM
6Fords's Avatar
6Fords
My V10 will not turn over after sitting for a few months. I have heard the motor turn over and it was running before I purchased it. It has a brand new battery and you can hear the starter hit when the key is in the start position, however nothing turns over. So far I removed the serp belt to make sure that none of the components such as A/C comp, etc. are not in a bind and my next move will be to try to turn the crank bolt with a pry bar. Attempting to do so with a 1/2" ratchet did not work. Would it make better sense to remove some or all of the plugs when doing so, or should I use the prybar as is? I am just wondering if anyone else has had issues like this. My next move would be removing the starter and having it tested, however the motor being tight is a concern. It just seems as if the motor is in some sort of a bind. Any comments/advice would be appreciated.
Sucker4aford
Mar 29, 2017 10:28 AM
6Fords
Nov 4, 2013 08:24 AM
LimmoDriver
Apr 24, 2012 07:02 PM
Future_LEO
Sep 23, 2010 07:53 PM
scooby3_4
Modular V10 (6.8l)
May 24, 2003 12:11 AM
