Juang's CV swap build thread.
Old Nov 11, 2013 | 10:14 AM
  #31
Roger Carter's Avatar
Roger Carter
Looking good,
Roger Carter
Old Nov 12, 2013 | 06:53 PM
  #32
juang316's Avatar
juang316
Well I got the motor in the truck with the motor mount brackets built. I had to notch the sides because they hit the mounts. The factory transmission cross member worked with the AOD perfectly and I didn't even have to drill holes. Oh and I finally caught my wrench thief. So if I get off early enough this week I hope to get the steering shaft and brakes all plumbed in. Maybe hear it run this weeked?
Old Nov 13, 2013 | 06:55 AM
  #33
Wolfracing's Avatar
Wolfracing
Pup has a look like "Busted!". LOL.
Nice build.
Old Nov 20, 2013 | 01:29 PM
  #34
SixtySix Ford's Avatar
SixtySix Ford
Nice build Jonathan! I sent you a couple emails.....
Old Nov 20, 2013 | 06:19 PM
  #35
juang316's Avatar
juang316
If you were sending me the emails never go them
Old Nov 21, 2013 | 08:18 AM
  #36
SixtySix Ford
I sent you a PM
Old Nov 23, 2013 | 09:49 AM
  #37
juang316's Avatar
juang316
Rain rain go away sorry venting some anger weather has been preventing work on the truck and my daily driver has a strong possibility to be sold in a couple of days
Old Nov 23, 2013 | 07:53 PM
  #38
juang316's Avatar
juang316
Update got the steering and brakes connected ready to put the front end back on and getting ready to get her started
Old Jan 9, 2014 | 07:27 PM
  #39
juang316's Avatar
juang316
Well its been awhile ive been quite busy putting the truck back together today i did some sound deadening and layed in the rubber floor mat. I got my floor mat from CG here in socal and now know it does not cover the whole floor ..... kind of a bummer. No fear though i rigged a solution apparently harbor frieght carries a rubber mat for use in tool boxes it works great not the same pattern but very moldable even though not as sturdy as the floor mat its covering low traffic use areas. ill post some pics later but just to keep you guys up to date.
Also side note does anyone know how to adapt a ford power steering pump from a 80's mustang to a 2011 crown victoria rack and pinion?
Old Jan 22, 2014 | 06:54 PM
  #40
juang316's Avatar
juang316
Ugh finally here are some pics
Old Jan 23, 2014 | 08:54 AM
  #41
Slixty4's Avatar
Slixty4
Great looking swap. I doing something similar. I am at the stage of designing and building my motor mounts for a 302.
What steering column did you use? I need something that tilts.
Old Jan 23, 2014 | 11:11 AM
  #42
juang316's Avatar
juang316
I have the dimensions for the mounts I used posted in this forum I have a 79 column just cut the flange off and order the 36 spline I believe from cpp the d rod and the ford rack triangle to d rod and your set
thebigyetti
Aug 4, 2011 09:50 AM
fordsforme!
Jul 17, 2011 09:36 AM
92Custom3006
Nov 25, 2007 02:45 PM
ladiabla74
Mar 19, 2004 07:05 AM
lostinLA
Mar 7, 2004 11:44 AM
