dip stick tube question.
Old Nov 11, 2013 | 02:42 PM
  #31
77mud's Avatar
77mud
Just got a new Dip stick tube and new O ring ordered and supposed to be here by next Monday, hoping Friday though so that I can put it in over the weekend.
Old Nov 11, 2013 | 03:43 PM
  #32
Ford4Life7.3's Avatar
Ford4Life7.3
Anyone know if you can put a SD dipstick on our trucks? They come up not the very front of the valve cover and much easier to get too, as well as mount easier without that silly little two piece thing ours use.
Old Nov 11, 2013 | 04:03 PM
  #33
77mud's Avatar
77mud
I thought about buying one to experiment and see if it would, but for now I just decided to get what I know would get me up and running
Old Nov 11, 2013 | 09:32 PM
  #34
oldbird1965's Avatar
oldbird1965
I wish I could relocate my auto dipstick, its in the way of my DP.
Old Nov 12, 2013 | 07:09 AM
  #35
77mud's Avatar
77mud
Maybe bend it a little?
Or pull it install dp then bend dipstick around it.
Old Nov 12, 2013 | 03:16 PM
  #36
OldWoodsDiesel's Avatar
OldWoodsDiesel
this thread is about the leaking dipstick adapter in the engine oil pan, right?
I just occurred to me - would it be possible to carefully tig weld the dipstick adapter to the oil pan? with the engine out and pan off the engine obviously... or is the dipstick adapter aluminum?
Old Nov 12, 2013 | 04:01 PM
  #37
77mud's Avatar
77mud
No it was about the dipstick tube not the bung in the.pan
Old Nov 12, 2013 | 04:07 PM
  #38
Ford4Life7.3
The dipstick adapter is brass. But….thats not a bad idea….i wonder if i could make or buy something that would work that is steel…..and Tig that on…..hmm.
Old Nov 13, 2013 | 06:44 AM
  #39
OldWoodsDiesel
what, you can't weld brass to steel? you must not have the right wire :-)
I bet there is something steel out there that could be made to work, though. once I get my oil pan off, maybe i'll put some work into a search - unless someone beats me to it.
Old Nov 13, 2013 | 01:31 PM
  #40
Ford4Life7.3
Mines off already Ill probably take a closer look today. I can envision machining a lip to go into the pan. Only part I can't really see is the part where the dip stick goes in.
Old Nov 14, 2013 | 05:36 PM
  #41
Thood81's Avatar
Thood81
I just bought that "o" ring from ford for around $5. The part number is 3c3z 6753 AA
Old Nov 14, 2013 | 06:24 PM
  #42
77mud's Avatar
77mud
Ive got one ordered already Thanks
2002fx4122
Oct 12, 2012 04:22 AM
Friesian-Bronco
Jun 8, 2010 08:39 PM
ponch37300
Apr 10, 2007 09:18 PM
kennedyford
Oct 31, 2006 11:13 AM
teamroper98
Jul 20, 2006 09:33 AM
