help.....
Old Oct 25, 2013 | 08:40 PM
madhatmaker's Avatar
madhatmaker
help.....
Im kinda new at this ,but I really need help...so I just bought this 91 f 150 its got the 4.9 six in it,5 speed manuel shift,so here is the deal,it seems to starte ok,but when you touch the gas peddle,it dies,and so if you start it again and rev it a lot it runs for a bit,but may die again.I have heard a lot about it either being a fuel pressure thing or the throttle positioning sensor,any good guesses?Im contemplating trying to test the fuel pressur first,then may attempt checking the tps,the last guy that had it said someone had put the fuel filter on backwards to get it to the auction house,am I correct in thinking there may be crud in the fuel lines?if so ,where would a knowledgeable person dis connect the lines to blow them out ? you can see why the help is needed...thanks in advance....
Old Oct 26, 2013 | 01:38 AM
Curtiswick's Avatar
Curtiswick
Checking the pressure at the fuel rail is a good start. That will tell you if the problem is forward (injectors and such) or backward (fuel lines, filters, pumps and such).
I'm still very new at all this also. I'm just re-typing from what I've read on a number of posts on this subject. There are some really knowledgeable folks on this site. I'm sure someone with a lot more experience will chime in to help. Good luck
Skchurch06
Jul 5, 2017 12:49 PM
desertdogs
Aug 6, 2014 05:12 PM
86bluebronco
1978 - 1996 Big Bronco
17
Jun 24, 2010 09:39 AM
RJF88
Aug 7, 2007 12:33 PM
collin1
1983 - 2012 Ranger & B-Series
Jul 30, 2002 07:03 AM
