does anyone know where i can find what these manifolds used to fit by the ford numbers. the numbers that i got are c9ve-9430-a and 9431-a. any help would be appreciated. thanks
They are exhuast manifolds for a 460 as used in a 1972 Lincoln Mark IV. The right one should have it's exhaust pipe connection below number 4 cylinder. If it isn't cracked, I could use it. Mine broke in two. It's a fairly common problem with them.
