Computer question: After Re-Gear
Old Oct 26, 2013 | 06:48 AM
DSN46's Avatar
DSN46
Originally Posted by hav24wheel
Way I figure it is if the 4.30s where available stock, might as well go lower if the tires are taller than stock. That way it performs as good or better than a 4.30gear/265 tire ex.
I run just shy of 3,000 rpms with 4.88s and 285s at 80 mph if I remember right. It pulls like mad. Even my Dad that has a 6.4l diesel was impressed how long it would hold OD pulling my camper and ATV trailer at 60 mph.
I completely understand what you are saying here. I guess my only concern is that I had both an old full size K5 Blazer and an 02 Tahoe that I had regeared to 4.56. Now, mind you I had them done BEFORE I put 35's on the wheels... I still had roughly 33" tires at the times of swap. Oh MAN did they feel low-geared! And that was okay because I knew 35's were coming for both. However, since I'm 2WD and stuck with the puny 285's, I'm nervous about 4.56 being too "RPM-Screamingly-Low" for my taste.
Did that make any sense? Basically, I'm just nervous about 4.56's.
Thanks again for everyone's input on this.
James
Old Oct 26, 2013 | 07:25 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by EXv10
Right, the sensor ring is "locked" to the rear wheels so only a tire size change or a sensor on the transmission would throw it off.
Would you please explain that? I don't understand how a trans sensor could throw off the vehicle speed signal.
Old Oct 26, 2013 | 08:13 AM
hav24wheel's Avatar
hav24wheel
James
Well like I said, I'm running same size tires as you, but with 4.88s. Here are some rpms in OD. So, with the 4.56s you would have a bit lower rpms.
Old Oct 26, 2013 | 08:30 AM
DSN46's Avatar
DSN46
Wow! Your RPM numbers aren't as high as I thought they would be. Thank you for posting that! Maybe I shouldn't be "skeered" about 4.56's.
James
Old Oct 26, 2013 | 09:00 AM
hav24wheel's Avatar
hav24wheel
I figured some hard #s might help you.
It's when it kicks down to D that they get high sometimes.
Old Oct 26, 2013 | 01:26 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by AlaskanEx
splitting hairs, ok Multiplying the TQ you ALREADY have and using it more efficiently.
I'm not splitting hairs, and I don't understand what you mean by multiplying the torque that's already there.
An engine produces power. Nothing the rear diff does can increase the power output of the engine, nothing. The diff gearing can move the torque produced by the engine lower in the RPM band (or higher up), but it cannot increase the power produced by the engine.
That's why there's "drivetrain loss" on a chassis dyno compared to an engine dyno. If the trans and diff could up the output of the engine, chassis dyno's would show a higher output, and there wouldn't be a drivetrain loss in power.
Stewart
Old Oct 26, 2013 | 01:58 PM
Mark Kovalsky
Stewart
My turn to split hairs.
The trans and rear gears can't move the torque to any other RPM. The engine makes a given torque at a given RPM and no gearing can change that.
What gearing CAN change is the tractive effort* at the tire/ground interface. A higher numerical gear (i.e., 4:30 vs 3.73) will produce more tractive effort at the ground for any given torque.
If the engine is making 500 lb-ft and the trans is in 1:1 ratio and the truck has a 3.73:1 axle ratio there will be 500lb-ft * 3.73 = 1865 lb-ft of torque in the axle shafts. With that same 500 lb-ft and 4.30:1 gearing the torque in the axle shafts is now 2150 lb-ft.
Ideally this torque will split 50-50 to each side, but that doesn't happen in reality. It is close enough for an approximation. Now if you multiply this torque by the rolling radius of the tire (something less than the unloaded diameter of the tire) you will get tractive effort. This is the force that moves the vehicle.
I've ignored drivetrain losses, but the loss between the same truck when changing from a 3.73:1 to a 4.30:1 ratio is negligible.
*tractive effort = the amount of force that the tires exert upon the ground to move the vehicle.
Old Oct 26, 2013 | 03:00 PM
Bigpipes 35's Avatar
Bigpipes 35
Dem hairs is a getting pretty thin
Old Oct 26, 2013 | 03:17 PM
EXv10's Avatar
EXv10
The trans spins more rpm's with lower gears while the rear axles are at the stock rpms so with a stock trans sensor (that they don't have anyway) the speed would be off. I should have never mentioned a transmission sensor scenario.
Old Oct 26, 2013 | 03:43 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Thank you sir, my point in a well thought out and explained in a nutshell
basically you can light'em up easier
Old Oct 26, 2013 | 04:12 PM
Stewart_H's Avatar
Stewart_H
Damn I love having you on the site, Mark! Reps!
Russ, if that was your point, then your post didn't convey that, because your post had the same misconceptions I've seen before on the 'net.
It's all good, as long as we're on the same page that changing the R & P gear doesn't increase torque provided by the engine.
Stewart
Old Oct 26, 2013 | 04:27 PM
Skip1970's Avatar
Skip1970
burn them tires man! nothing cooler then roasting them new expensive hogs!
Old Oct 26, 2013 | 04:29 PM
  #28
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Stewart
i may be stupid (an nobody is arguing that) but i ain't THAT stupid.
holding O/D longer when towing or on large grades, more off the line power/TQ and like i said the ability to light'em up
Old Oct 26, 2013 | 04:54 PM
  #29
EXv10's Avatar
EXv10
Torque multiplication was just a poor choice of words and torque is rarely multiplied but an example of it is in a torque converter where the stator redirects the fluid and truly multiplies torque. There is no torque multiplication when going to lower gears, there is merely a shift of torque.
Old Oct 26, 2013 | 05:50 PM
  #30
DSN46's Avatar
DSN46
Guys! Guys!
Didn't mean to start all this....
I'm going with 4.56.
Thank you all!
James
